Вики, созданная, благодаря помощи студентов
Эта вики выполнена отличной студенческой командой из нашей образовательной программы.
Audio often fails
You try to play music out loud on your device, but the sounds are either distorted or not heard.
Low or muted volume level
If there is distorted sound or no sound, you should go to the settings then to sound and make sure your device is not muted. You could also turn the volume up by pressing the buttons on the side of the tablet. Lastly, make sure the volume is up on the app that you are using. If these two things do not work, the last resort is to reset the device, power it back on, and check the sound.
Broken speaker
If the sound still does not work after you reset the device, you should replace the speaker. You could properly replace the speaker by following this guide.
Headphones often do not stream audio
You plug your headphones into the device, but you hear no sounds.
Broken headphones
To distinguish if the problem lies within your headphones or your device, try using your headphones on another compatible device. If the headphones stream music on an alternative device, there is likely a problem with your tablet.
Broken headphone jack
A broken headphone jack will prohibit you from streaming music on your tablet through headphones. For help on replacing your headphone jack, take a look at our replacement guide.
Short battery life
Your tablet will die shortly after you charged it overnight or the battery will dwindle rapidly even when you are not using the device.
Faulty charger
Chargers can often be damaged or broken as a result of use. Find a device with the same charging port. Plug your charger into that device. If that device does charge and does not die shortly after, there is likely a problem with your tablet.
Broken battery
It is common for batteries to expire in all types of devices. For help on replacing the battery of your Insignia flex 10.1 tablet, look for our replacement guide.
The tablet will not turn on
Your tablet is completely unresponsive and you are unable to turn it on even after charging it.
Broken battery
Batteries can expire which will cause the device to be unresponsive despite charging efforts. If you replace the battery in your device, and it is still unresponsive, it is likely that the problem lies with the motherboard.
Broken Motherboard
A faulty motherboard will cause the device be unresponsive despite a working battery. With help on how to replace the motherboard of your Insignia Flex 10.1 tablet, take a look at our replacement guide.
The screen does not show content
The screen on your device no longer displays content clearly, or has a crack in it.
Device needs to be reset
To reset your device, turn it off for several minutes and then turn it back on. Next proceed to your settings. Find the backup and reset tab. Proceed to factory data reset and click reset device. If the screen is still distorted after this process, it is likely that your screen is broken and needs to be replaced.
Broken screen
Broken screens can create an unpleasant user experience on this tablet. If your screen is cracked, or shows distorted content even after being reset, likely it needs to be replaced. Find help on how to replace the screen of your Insignia Flex 10.1 tablet on our replacement guide.
Один комментарий
My home button don't work
Rafael Ortiz - Ответить
