LG Prime Troubleshooting
No matter what you do, you can't get your LG Prime to turn on.
Before delving into the guts of your iPod, .... read on.
If your iPod won't turn on, .... We sell batteries for both 30 GB and 60/80 GB Video iPods.
It is possible that it appears nothing is happening because the display is bad. If .... it is possible the display is bad and must be replaced.
If .... the problem most likely lies in the logic board.
You're trying to listen to a song and can't hear a thing.
The phone may be set to the lowest volume setting; try to increase the volume using the toggles on the left side of the phone.
Navigate to the phone settings to check to see if the phone is set to silent mode, or is set to airplane mode. Disable these settings and test the sound again.
Make sure the headphones are fully inserted. If the problem persists, remove the headphones and blow gently into the jack to free debris. Insert the headphones and test the sound again. If the problem persists, you may need to replace your headphone jack, find our guide here.
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 1
За всё время: 107
