Вики, созданная, благодаря помощи студентов
Эта вики выполнена отличной студенческой командой из нашей образовательной программы.
Matsunichi MaquisPad MP977 Troubleshooting
This is a trouble shooting page for the Matsunichi MarquisPad MP977. It will leave you with solutions to basic issues you may encounter with your device.
MarquisPad will not turn on
The MarquisPad will not power on when pressing the power button.
Try charging the device
Plug the charger into the device, and plug the other end into the wall. Allow it to charge for at least 4 hours; then turn on.
Soft reset device
Hold down the power button until the device turn off. Wait a few minutes; then turn the device back on.
Reset using a computer
Obtain a charging cord for the device that plugs into the device on one end, and has a USB plug on the other end. Plug this USB end into the computer and try to reset the device.
MarquisPad camera malfunction
The front facing camera will not take photos.
Soft reset device
Hold down the power button until the device turns off. Wait a few minutes; then turn it back on.
Full memory
Find the settings tab, select “About This Device” to see the memory usage distribution. If the memory usage is full, the device will not be able to store new images, you may need to delete items off the device before proceeding.
Camera is off
Again, under the settings tab on your device, select “Camera” to view its settings, be sure the camera is turned on.
Blocked camera
Be sure that the camera is clean and clear and there is nothing covering the camera while you are trying to use it.
MarquisPad will not charge
The MarquisPad will not charge even when plugged into the charger.
Broken charger or charging port
Check the alignment of the charging head in the charging port. If they are not flush, the device will not charge properly.
Make sure USB is fully inserted
Check the connection between the USB charging cord and the USB port on the wall power adapter or computer. If the USB head is not seated in the receiving port correctly, the device will not charge properly.
Make sure wall outlet is live
Make sure the wall outlet being used is live by plugging in a different device, such as a lamp. An alternative is to test your charging plug on a different outlet to see if it is the outlet or your charging cord that's damaged.
Check charging wire for damage
If you do come to the conclusion that it may be an issue with your charging cord, glance over the cord for any damage. If you can observe an exposed wire or major issues, you may need to purchase a new charging cord.
MarquisPad will not recognize microphone
The microphone is not being recognized by the device and cannot be used.
Soft reset device
Check microphone settings
Again, under the settings tab on your device, select “Microphone” to view its settings, be sure the microphone is turned on.
Blocked mic
Be sure that the microphone is clean and clear and there is nothing covering the microphone while you are trying to use it.
MarquisPad will not accept password
The password is not being recognized, and therefore the device cannot be used.
Soft reset device
Reset using computer
Try "forgot password" option
Select the “Forgot Password” button which is located underneath the password box on the device lock screen. This page will prompt you to answer security hints that you originally set when you acquired the device. If you do not remember your answers to these question, you can have an email sent to you with more instructions.
Factory reset device
Plug the device into a computer as mentioned above. Select the device options menu on your computer screen and select “Restore Factory Settings”. This will wipe all of the data on the device, allowing a new password to be set and used.
4 Комментариев
Screen freezes on turning on and won't respond to power off? How do I reboot?
Sheila Hebert - Ответить
Stuck at splash screen. In a boot loop. How can I fix it? What software is needed to interface with a pc? Does anyone know where to obtain a new charge port for replacement?
mattyg2k6 - Ответить
I have android version 4.0.3 Is there an update?
Bill Reisenbuchler - Ответить
I did a factory reset now I can’t get google to work every time I enter user name and password it’s says it doesn’t match records. I’ve tried everything can’t do updates or anything. Need help
Amanda Wilmoth - Ответить
