Вики, созданная, благодаря помощи студентов
Эта вики выполнена отличной студенческой командой из нашей образовательной программы.
Tire will not stay inflated
Bicycle tire will not hold air even though you've been inflating it.
Inner tube is leaking air
Although patching a tube may be possible, it is ideal to just replace it.
Tire has a tear in it
It is possible for the tube to be working probably while the tire is still flat. This would only happen if the tire was damaged. You would have to replace the tire to fix this.
Pedals do not make the bike move
Your bike can roll, but the pedals are what is making it move.
The chain fell off
Sometimes the chain can fall off, or come off of the sprocket. This is an easy fix that only requires putting the chain back on the sprocket and possibly needing to tighten the chain.
The chain broke
If the chain is broken you may need to replace it. You can avoid replacing the whole chain if only a link or two are damaged, but you'll need extra links.
Handle bars are squeaky
While riding the bike your handle bars make a lot of noise and squeak while turning and maneuvering.
Faulty ball bearings
Sometimes the ball bearings just get old and rusty and no longer allow turning with minimal friction. If oiling the ball bearings does not solve the problem then they will need to be replaced.
Headset is dry
In other words, the headset and the fork have no oil between them and the metal on metal is making the squeaking noise. You will need to remove these two parts and oil the fork where the headset overlaps it.
Seat moves freely
The seat either moves up and down or rotates forward and backward easily.
Loose bolts
Sometimes this problem is fixed simply by tightening some loose screws.
Broken seat clamp
If the seat clamp is broken then it probably needs to be replaced. The seat clamp is not easily repaired.
Один комментарий
rear wheel doesn’t turn backwards
birdcage220 - Ответить
