Как мы оцениваем устройства:
Отремонтировать устройство с наивысшим баллом можно относительно недорого — оно легко разбирается и продаётся в комплекте с инструкцией по ремонту. Количество присуждаемых баллов зависит от того, насколько сложно вскрыть устройство и заменить основные детали, а также от типа крепежа. Дополнительные баллы начисляются за возможность модернизации, за отсутствие необходимости в специальных инструментах и за модульность компонентов.
Сортировка по параметрам: Публикация | Оценка
Microsoft Surface Duo
  • Batteries are glued and require extensive disassembly to service.
  • The USB-C port is soldered directly to the main board.
  • Uncommon tri-point screws secure key components.
2
Samsung Galaxy Note 20 Ultra
  • Battery replacement remains far too difficult for a consumable component.
  • Screen repairs are tedious, poorly prioritized, and unnecessarily expensive.
  • You'll only need one screwdriver, a standard Phillips.
3
iPhone SE 2020
  • The two most commonly replaced components, display and battery, remain straightforward to access with the proper knowledge and tools.
  • Most components are modular and independently replaceable, including many that are cross-compatible with iPhone 8.
  • The fragile glass back is impractical to replace.
6
Samsung Galaxy A51
  • Screen repairs require a lot of disassembly while battling tough adhesive.
  • The plastic back cover is glued in place, but can be removed fairly easily with heat.
  • A single Phillips driver takes care of all the screws.
4
Samsung Galaxy S20 Ultra
  • Every repair starts with painstakingly un-gluing the fragile glass rear cover.
  • Replacing the glued-down battery is tougher than ever, especially with board interconnect cables to work around.
  • The fasteners, all identical Phillips screws, only require one driver and can't be mixed up, simplifying repair.
3
Samsung Galaxy Z Flip
  • Glued-down glass panels are an unnecessary barrier to entry for repairs, especially given the phone's lack of ingress protection.
  • Battery replacements are possible, but unnecessarily difficult due to poorly-routed cables and the lack of stretch-release adhesive.
  • The components involved in the folding process are likely to wear over time (even if you don't bathe them in purple dust), necessitating eventual replacement.
2
Motorola razr
  • Every repair starts (and ends) with stubborn, glued-on outer covers.
  • Replacing the battery—or rather, batteries—requires near-total disassembly.
  • The charging port is soldered directly to the main board.
Google Pixel 4 XL
  • Display repairs continue to be difficult, requiring complete disassembly of the phone.
  • All repairs require access through the stubbornly-glued back panel.
  • All screws are standard T3 Torx fasteners.
4
iPhone 11
  • The prioritized display makes replacement of this critical component easier than in other devices.
  • Display swaps don’t require too much hardware swapping to maintain Face ID.
  • Front and back glass doubles the chances of breakage, and the rear glass can only be fully replaced with a complete housing swap.
6
iPhone 11 Pro Max
  • Critical display and battery repairs remain a priority in the iPhone's design.
  • The battery procedure has been simplified and many components are accessible independently.
  • Glass on front and back doubles the likelihood of drop damage—and if the back glass breaks, you'll be removing every component and replacing the entire chassis.
6
Fairphone 3
  • Key components like the battery and screen have been prioritized in the design and are accessible either without tools or just a regular Phillips screwdriver.
  • Visual cues inside the phone help with disassembling and replacing its parts and modules.
  • Replacing complete modules is very easy. Going for their internal parts is also possible and requires a Torx screwdriver.
10
Samsung Galaxy Note10 Plus 5G
  • Equally-sized Phillips fasteners means you only need to bring one driver for repairs.
3
Shift 6m
  • Battery and screen repairs are prioritized.
  • Only one type of screw head and length are used throughout the phone.
  • The manufacturer provides a few repair guides, and a screwdriver is shipped with the phone.
9
Huawei Mate 20 X 5G
  • Glued-down front and back glass means greater risk of breakage, while making all repairs difficult to start.
  • Screen repairs will require near-complete disassembly.
  • Many components are modular and can be replaced independently.
4
Google Pixel 3a
  • Most components are modular and can be easily replaced once the display assembly is removed.
  • Repair-friendly stretch-release adhesive secures the battery.
  • The myriad long, thin ribbon cables connecting the internal componentry can be obnoxious to work around, and are easy to accidentally tear.
6
Google Pixel 3a XL
6
Samsung Galaxy Fold
  • The mechanics involved in the fold are likely to wear over time, causing stress to hinges and display, necessitating eventual replacement.
  • The fragility of the main display means you'll almost certainly be replacing it before long—a pricey repair.
  • Battery replacements are possible, but unnecessarily difficult—solvents help, but risk damage to the display supports.
2
Samsung Galaxy S10
  • Battery replacement is possible, but still unnecessarily difficult.
  • Glued-down glass both front and back means greater risk of breakage, and makes repairs difficult to start.
3
Huawei Mate 20 Pro
  • Glued-down front and back glass means greater risk of breakage while making repairs difficult to start.
4
iPhone XR
  • The display-first opening procedure and easy access to the battery remain design priorities.
  • A broken display can be replaced with minimal hardware removal, and with a little care you can preserve Face ID.
  • Glass on front and back doubles the crackability—and broken back glass requires an entire chassis replacement.
6
Google Pixel 3 XL
  • Display repairs are much more difficult than previous models, requiring complete disassembly of the phone.
  • To service any component, you'll have to painstakingly un-glue (and later re-glue) the glass rear panel.
  • The only screws are standard T3 Torx fasteners.
4
Google Pixel 3
4
iPhone XS
  • A broken display can be replaced without removing the biometric Face ID hardware.
6
LG G7 Thin Q
  • Front and back glass make for double the crackability, and strong adhesive on both makes it tough to access the internals for any repair.
  • Screen repair, the most common type repair, is not prioritized, requiring an almost complete disassembly while battling tough adhesive.
  • Lots of components are modular and can be replaced independently.
4
OnePlus 6
  • Display replacement, the most common repair, is not prioritized in the design and will take a lot of work.
  • Front and back glass means twice the risk of cracks—without even the benefit of wireless charging.
  • The battery can be accessed almost the moment you open the phone, and is only lightly adhered in place. Plus, there's a convenient pull tab.
5
Huawei P20 Pro
  • Double the risk for breakage with glass front and back.
  • Replacing the screen requires going through at least two layers of adhesive and some disassembly.
4
Samsung Galaxy S9
4
Samsung Galaxy S9 Plus
4
iPhone X
  • Display and battery repairs remain a priority in the iPhone's design.
  • A cracked display can be replaced without removing the biometric Face ID hardware.
  • Fussy cables tie unrelated components together into complex assemblies—expensive and troublesome to replace.
6
Google Pixel 2 XL
  • Many components are modular and can be replaced once the display assembly is removed.
  • All of the screws are common Phillips #00 screws, and there are only 9 of them.
  • The battery's loss of pull-tab adhesive, plus tightly walled-in placement, makes it much harder to remove.
6
Google Pixel 2
  • Переднюю панель довольно легко снять и заменить.
  • Стандартные винты, используемые по всему миру.
  • Размещение кабеля делает выемку аккумулятора более сложной чем обычно.
6
Huawei Mate 10 Pro
  • A damaged front camera means switching the whole display including the frame, or damaging the display while trying to remove it.
  • And replacing the display—the most common repair—means taking out almost every component.
  • Despite the IP67-rated seals, the back cover is fairly easy to open.
4
iPhone 8 Plus
  • The display and battery are straightforward to access—with the proper knowledge and tools.
  • Wireless charging means less wear on the all-purpose Lightning port, a common point of failure.
  • Despite alleged durability, the back glass is breakable and next to impossible to replace when cracked.
6
iPhone 8
  • The addition of wireless charging means less strain on your Lightning port, a common point of failure.
  • The durability of the glass back remains to be seen—but replacements are likely to be very difficult.
6
Samsung Galaxy Note8
  • All repairs require removing the glass rear panel, which is challenging due to the large amount of adhesive.
  • Replacing the display requires removing the glass rear panel and the display, both of which are fragile and secured with strong adhesive.
  • Many components, including all of those that experience wear, are modular and can be replaced independently.
4
Essential Phone
  • The USB-C port is soldered to the motherboard, and with no headphone jack it'll be subject to extra wear.
  • Nearly invisible seams and copious adhesive means any attempt at repair is likely to inflict as much damage as it fixes.
  • Did we mention we had to freeze it?
Samsung Galaxy Note Fan Edition
  • Front and back glass make for double the crackability, and strong adhesive on the rear glass makes it very difficult to gain entry into the device.
  • Because of the curved screen, replacing the front glass without destroying the display is probably impossible.
4
OnePlus 5
  • There are no proprietary screws.
  • The OnePlus 5’s display is held on by easy to dispatch reusable plastic clips.
  • The display and glass are fused and the home button is integrated into the display assembly making repair of all three of these parts more complicated and expensive.
7
Samsung Galaxy S8
  • Because of the curved screen, replacing the front glass without destroying the display is extremely difficult.
4
Samsung Galaxy S8 Plus
4
LG G6
  • Front and back glass doubles the crackability, and strong adhesive on both makes it tough to begin any repair.
  • Components adhered to the back of a fused display assembly.
5
Huawei Mate 9
  • Replacing a broken display, one of the most common repairs, will be one of the most difficult ones on this phablet.
  • The battery is trapped behind some flex cables and is glued tightly into place, but still can be swapped out when its power starts to fade away.
  • Most of the components—like both camera units, the loudspeaker, and the USB board—can be replaced. Even the proximity sensor and the NFC antenna are modular.
5
Google Pixel
  • Аккумулятор крепится с помощью съёмных липких выступов, что облегчает замену.
  • Многие компоненты являются модульными и могут быть заменены независимо.
  • Данного типа дисплей тонкий и не поддерживается, и должен быть удалён для доступа к любому другому компоненту.
7
Google Pixel XL
  • Many components are modular and can easily be replaced once the display assembly is removed.
  • The battery has a removal tab and is adhered by a modest amount of adhesive, making its removal painless.
  • The opening procedure requires prying up a thin, poorly-supported display assembly making it difficult to open the phone without damage.
7
iPhone 7
  • The battery is straightforward to access. Removing it requires specialty screwdrivers and knowledge of the adhesive removal technique, but is not difficult.
  • The solid state home button eliminates a common point of failure.
  • With the addition of tri-point screws, many iPhone 7 repairs will require up to four different types of drivers.
7
iPhone 7 Plus
  • With the addition of tri-point screws, many iPhone 7 Plus repairs will require up to four different types of drivers.
7
Sony Xperia X Compact
  • Modular design allows for replacement of many individual components.
  • Battery is fairly easy to access and remove, but requires removal of the delicate NFC antenna to replace.
  • Adhesive used throughout will need to be replaced during reassembly, and may never be as waterproof again.
6
Moto Z
  • Pull-tab on battery, easy to access once you have the device open.
  • Modular assembly allows independent replacement of many components
  • Charging port soldered to the motherboard means a common repair will be very expensive.
7
Samsung Galaxy Note7
4
Asus Zenfone 3 Max
  • Battery is easily accessible and removable.
  • Parts could be more modular, especially mechanical/high wear components.
  • The opening procedure is extremely tough, clips are stiff and likely to be broken, and the SIM slot bends easily.
6
Meizu MX6
  • The display assembly is the first component out, simplifying screen repairs.
  • Modular components with spring contacts, large screws, and thoughtful cabling all make repair cheaper and easier.
  • The MX6 uses Pentalobe security screws on the exterior, requiring a specialty screwdriver to open the phone before any repair.
7
LG G5
  • The user-removable, slide-out battery is a huge boon to phone lifespan.
  • No glue and few screws make for a relatively simple opening procedure.
  • The fused display assembly will need to be replaced if the LCD or glass breaks, increasing costs.
8
Vivo X7 Plus
  • Battery is fairly easily accessible and removable.
  • The single unit display assembly is annoying to reach, and will be a costly part.
7
Vivo X7
  • The opening procedure is extremely tough, clips are very stiff and likely to be broken.
6
Huawei P9
  • Modular components with spring contacts, thoughtful cabling, and minimal adhesive all make repair cheaper and easier.
  • The battery is straightforward to access. Removing it requires knowledge of the adhesive removal technique, but is not difficult.
  • The display assembly is a fused unit, and replacement requires near complete disassembly of the phone.
7
Xiaomi Mi 5
  • The motherboard and battery can be replaced independently and easily.
  • Most components are modular and can be replaced independently.
  • The display is difficult to replace, requiring complete disassembly and purchasing consumables.
6
iPhone SE
  • The display assembly is the first component out of the phone, simplifying screen replacements.
  • The battery is fairly easy to access, even though it's not technically "user replaceable."
  • The Touch ID cable could be easily ripped out of its socket if a user is not careful when opening the phone.
6
Oppo R9m
  • Most components are extremely modular making for cheaper repairs.
7
Samsung Galaxy S7
  • The display needs to be removed (and likely destroyed) if you want to replace the USB port.
3
Samsung Galaxy S7 Edge
3
Lenovo K5 Note
  • Battery is replaceable with just a couple of tools.
  • A single Phillips 00 driver takes care of all the screws.
  • Replacing the display assembly requires removing every other component from the device first.
6
Fairphone 2
  • The most commonly failing components, battery and display, can be replaced without tools.
  • Internal modules are secured with Phillips #0 screws and simple spring connectors.
  • Individual modules can be opened, and many components can be individually replaced.
10
Huawei Mate 8
  • Many components are modular and can be individually replaced.
  • Opening the phone requires only a Torx screwdriver and a prying tool (No adhesive holding it together).
  • A tamper evident sticker must be removed when disconnecting the battery.
6
Xiaomi Redmi Note 3
  • Despite no external screws, the rear case is fairly easy to remove.
  • Battery is easy to access and remove.
  • Display assembly is a single fused component, that requires disassembling the entire phone to replace.
8
Wiko Pulp 4G Phone
  • Replacing the battery is easy as pie with the swappable back cover.
  • This phone doesn't use excessive glue nor proprietary screws—we found only Phillips throughout the entirety.
  • Unfortunately, the components on the daughterboard are soldered on, making a repair on an individual component difficult.
7
iPhone 6s Plus
  • Конструкция дисплея достаётся самой первой, упрощая его ремонт.
  • Вынуть батарею тоже не так уж и сложно. Вам потребуется отвёртка под проприетарные шлицы Pentalobe и знание техники избавления от клея, но трудностей со всем этим не возникнет.
  • На корпусе iPhone 6s по-прежнему используются проприетарные винты Pentalobe. Вам не обойтись без специальной отвёртки.
7
iPhone 6s
7
Nexus 5X
  • Standard Phillips screws means a driver is easy to find.
  • Fused display assembly—glass and LCD will need to be replaced together if one or the other breaks.
7
Nexus 6P
  • It's very difficult—although not impossible—to open the device without damaging the glass camera cover. Because of the unibody design, this makes every component extremely difficult to replace.
  • The display assembly cannot be replaced without tunneling through the entire phone. This makes one of the most common repairs, a damaged screen, difficult to accomplish.
  • Tough adhesive holds the rear cover panels and battery in place.
2
OnePlus 2
  • A single (non-proprietary) screw head decreases cost of tools for repairs.
  • The LCD and digitizer glass are fused together and must be replaced as a single part; heat is required to remove it from the midframe.
7
Shift 5.1
  • Cover and battery are easy to remove and can be swapped without using tools.
  • No excessive glue and no proprietary screws are used, only Phillips #000.
  • Lots of components and connectors are soldered to the motherboard. They could be soldered by hand if needed but this makes repairs more difficult.
6
LG G4
  • Rear panel and battery can be removed with no tools.
8
Samsung Galaxy S6
  • Replacing the glass without destroying the display is probably impossible.
4
Samsung Galaxy S6 Edge
  • The battery is very tightly adhered to the back of the display, and buried beneath the midframe and motherboard.
3
HTC One M9
  • The battery is buried beneath the motherboard and adhered to the midframe, hindering its replacement.
  • The display assembly cannot be replaced without tunneling through the entire phone. This makes one of most common repairs—a damaged screen—very difficult to accomplish.
  • Intense adhesives make many components difficult, and even dangerous, to remove and replace.
2
Nexus 6
  • Pressure contacts and cable connectors make the modular components (cameras, buttons, headphone jack) easy to replace.
  • The Nexus 6 uses a single kind of screw, although it's a fairly uncommon size (T3).
  • Several components (vibrator, SIM slot, speaker, USB port) are soldered directly to the motherboard and will be more difficult to replace than if they were connected by cable.
7
iPhone 6
  • Продолжая тренд, заданный iPhone 5, дисплейный модуль отделяется в первую очередь, что упрощает замену дисплея (самая частая поломка).
  • Батарею поменять тоже несложно. Нужны отвертки для pentalobe-винтов и умение аккуратно снять пластиковые пломбы. Но это не сложно.
  • В iPhone 6 используются нестандартные pentalobe-винты, которые требуют специальных отверток.
7
iPhone 6 Plus
  • В iPhone до сих пор используются pentalobe-винты, которые требуют специальных отверток.
7
Samsung Galaxy Alpha
  • The display assembly is held in with a significant amount of adhesive and requires very careful prying and a considerable amount of heat to remove without cracking the thin glass or cutting cables.
  • Replacing anything other than the battery requires first removing the display, risking extra damage on the way to a repair.
  • The battery is incredibly easy to remove and replace.
5
Amazon Fire Phone
  • Tons of cables and connectors make disassembly tedious and reassembly difficult.
  • The four Dynamic Perspective cameras are encased in glue. Replacement will mean heat and cutting.
  • External, non-proprietary screws means no adhesive holding the device together, and an easier time getting in.
3
Samsung Galaxy S5 Mini
  • The display is now one of the first components out, making its replacement a little faster. However, it is held in with a significant amount of adhesive and requires very careful and persistent prying, as well as a considerable amount of heat to remove without cracking the glass or cutting cables.
5
OnePlus One
  • With its connector trapped under a plastic panel and several screws, the battery is more of a chore to replace than necessary.
  • The LCD and digitizer glass are fused together and must be replaced as a single part, and they require heat to remove from the midframe.
  • No proprietary screws and only one screw head type decreases cost of tools for repairs.
5
Samsung Galaxy S5
  • The display is now one of the first components out, making replacements a little faster. However, it is held in with a significant amount of adhesive and requires very careful and persistent prying and a considerable amount of heat to remove without cracking the glass or cutting cables.
5
HTC One M8
  • It's very difficult—although no longer impossible—to open the device without damaging the rear case. This makes every component extremely difficult to replace.
  • The display assembly cannot be replaced without tunneling through the entire phone. This makes one of most common repairs, a damaged screen, very difficult to accomplish.
2
Fairphone 1
  • The battery can be replaced without any tools.
  • It's very easy to open and access the internal components.
  • Several smaller components are soldered to the motherboard, increasing repair difficulty (front-facing camera, vibrator motor, LED flash, and headphone jack).
7
Nexus 5
  • Very modular design allows independent replacement of several wear-prone components—like the headphone jack and speakers.
  • Only very mild adhesive holds the battery in place, making it fairly easy to safely remove and replace.
  • The glass and LCD are fused to the display frame. Fixing broken glass will be either expensive or very difficult.
8
iPhone 5s
  • Just like in the iPhone 5, the display assembly is the first component out of the phone, simplifying screen replacements.
  • The battery is still fairly easy to access, even though it's not technically "user replaceable."
  • The fingerprint sensor cable could be easily ripped out of its socket if a user is not careful while opening the phone.
6
iPhone 5c
  • Adhesive on the antenna connectors hinder disassembly.
6
Motorola Moto X 1st Generation
  • Pressure contacts and cable connectors make the modular components (cameras, buttons, headphone jack and speakers) easy to replace.
  • The Moto X uses a single kind of screw, although it's a fairly uncommon size (T3).
  • Sticky adhesive on the back cover is annoying and will slow opening the phone.
7
Samsung Galaxy S4
  • The battery can be replaced in seconds, without any tools.
  • Very easy to open and access internal components.
  • The glass is fused to both the display and the display frame, increasing repair costs.
8
HTC One
  • Very, very difficult (possibly impossible?) to open the device without damaging the rear case. This makes every component extremely difficult to replace.
  • The display assembly cannot be replaced without removing the rear case—this will make the most common repair, a damaged screen, nearly impossible.
BlackBerry Z10
  • Motherboard and display come out with little difficulty and are held in place with little adhesive.
  • Smaller components (headphone jack, camera) are modular and can be replaced individually, but have somewhat strong adhesive holding them in place.
8
Nexus 4
  • Removing the back cover requires nothing more than a common screwdriver, a plastic opening tool, and some patience.
  • The entire device only contains four different length screws—all common screw types—for a total of only 15 screws.
  • The battery is stuck to the frame with a lot of adhesive, so removing it without puncturing the battery can be difficult.
7
Samsung Galaxy Note II
  • Аккумулятор легко заменить.
  • Очень легко открыть для доступа к внутренним компонентам.
  • Компоненты приклеены к задней части слитого дисплея.
8
iPhone 5
  • We're quite happy that the glass/display is the first thing that comes off the iPhone 5. The majority of iPhone repairs are due to a shattered front glass.
  • The battery comes out with a bit of prying once the front panel is removed.
  • The iPhone 5 still uses Pentalobe screws on the exterior, making it more difficult to open the device.
7
Samsung Galaxy S III
8
Motorola Droid 4
  • Keyboard contacts are located on the motherboard, making keyboard replacement costly and difficult.
  • Tons of glue adheres the glue that is securing the glue to the glue that holds the phone together.
  • The lack of security or proprietary screws is a welcome sight.
4
Samsung Galaxy Nexus
  • Battery replacement is incredibly simple thanks to the removable rear panel.
  • Minimal adhesive makes removal of the motherboard and other components a snap.
  • Removing the rear case to access the motherboard and other internals requires a lot of careful prying and guitar-picking.
7
Motorola Droid RAZR
  • The front panel is adhered to the AMOLED display, so they must be replaced as one expensive unit.
  • All plastic frames and casing proved to be incredibly tedious to remove, and felt like they would break at any moment.
  • Once the battery and motherboard are within reach, replacement is easy—no soldering required.
4
iPhone 4S
  • The iPhone 4S is still held together primarily with screws and limited adhesive.
  • The rear panel and battery are both easy to remove and replace (provided you have the correct screwdriver).
  • Apple is again using Pentalobe screws to secure the rear panel and keep people out
6
Samsung Galaxy Note
8
Motorola Droid Bionic
  • No tools are necessary for changing the SIM and microSD cards.
  • The battery can be removed in seconds.
  • The phone is held together with a limited number of screws and plastic clips. Adhesive is minimally used in its construction.
9
Motorola Droid 3
  • There were no security screws in the entire device.
  • The battery was not soldered to anything and was easy to replace.
  • There is a lot of adhesive holding things together, making disassembly and reassembly difficult.
6
Samsung Galaxy S II
8
Samsung Galaxy S 4G
  • Removing the rear panel to replace the microSD/SIM cards and the battery requires no tools.
  • Attaching components like the headphone jack to separate cables makes their replacement less costly than replacing the entire motherboard.
6
iPhone 4 Verizon
  • The iPhone 4 is held together primarily with [lots of] screws, sans tabs, and limited adhesive.
  • The rear panel and battery are both easy to remove and replace (provided you have the right screwdriver).
  • Apple is using Pentalobe screws to secure the rear panel and keep people out.
6
Motorola Atrix 4G
  • The LCD is separable from the glass front panel, making them independently replaceable.
9
Nexus S
  • Battery is very easily replaceable -- just remove the back cover to swap it out.
  • The motherboard comes out easily once you're inside, as it's held in place by regular screws and connectors.
  • Front panel is attached with adhesive instead of screws, so it's harder to take off than on the iPhone.
7
HTC Surround
  • Unable to access the internal MicroSDHC card without voiding the warranty.
  • It is very difficult to access the front panel and LCD for replacement.
  • Relatively easy to remove the rear case to replace the battery.
5
Nokia N8
  • The battery, although considered by Nokia not to be user-serviceable, can be easily removed.
  • The AMOLED display easily comes apart from the glass, which means that you can replace the glass and the display independently.
  • Removing the cameras is near-impossible, and requires tedious, potentially detrimental steps.
8
iPhone 3GS
  • LCD and front glass are not fused and can be replaced individually.
  • Standard Phillips screws used throughout.
  • Battery is buried under the logic board, making it difficult to replace.
7
iPhone 3G
7
iPhone 1st Generation
  • Hidden clips make it nearly impossible to open rear case without damaging it.
  • Soldered battery is very difficult to replace.
2
