Дата выхода 25 сентября 2015 г. Модель A1688 / A1633. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 16, 64 или 128 ГБ памяти; в цветах: Серебристый, Золотой, «Серый космос» и «Розовое золото».
2694вопросов Показать все
iPhone stuck in Boot Loop only when plugged in to power outlet.
Hello everyone,
My iPhone 6s fell this past weekend and since then has been stuck in a boot loop (apple logo appears and disappears) whenever it is plugged in to an outlet.
Ultimately I'd like to pull the data out of my phone via iTunes backup, but the problem I'm facing is that my iPhone does not seem to boot up when plugged in to my PC's usb port.
Anyone have an idea how I can enact atleast a bootloop on a PC or get my turned off iPhone recognized in iTunes?
I tried finding answers via search, but nothing seems to touch on the issue of my iPhone not booting when plugged in to a usb port on the PC.
Thank you.
Это хороший вопрос?
Оценка 5
1 Комментарий
I had the same problem. It may be a software issue but most likely the battery connecter is loose. I went to a nearby phone service shop and he opened it up right in front of me, and the battery connecter had gone loose, just like a little lego.
из
Добавить комментарий
7 Ответов
Выбранное решение
Here are some things to try when you are faced with a boot-looping phone.
  • Try a hard reset (Home & Power button for 10 secs)
  • Use a genuine Apple Lightning connector
  • Use a genuine Apple charging brick and let it charge overnight
  • Try to connect it to different computers (mac/pc if possible) with an updated iTunes
  • Put the phone in recovery mode (search DFU Mode). Careful, this can reset your data
  • Use 3uTools for putting it in and out of Recovery Mode
  • Use 3uTools to flash the firmware (you can't downgrade)
  • Check the condition of all the flexes (with magnification)
  • Disconnect the Front Camera Ribbon from the logic board and reboot your phone
  • Disconnect the screen assembly completely and see if iTunes will recognize the phone.
Otherwise, you may have a logic board issue. If you are uncomfortable doing these steps, consider finding a repair shop to do the troubleshooting. A shop that also does micro-soldering can go deeper if the problem is not modular in nature.
Был ли этот ответ полезен?
Оценка 3
@jasrotia_1 did you ever find the solution, I have the same problem.
Оценка 1
1 Комментарий:
It some hardware issue. I gave to technician (not Apple Auth)
He replaced a chip . It was all fine thereafter
But exactly what chip he replaced I am not aware
из
Hi everyone and thank you for the responses.
It turned out my phone had simply died and I ended up having to go with the hard reset in order for my phone to work again.
Оценка 0
2 Комментариев:
Can you explain how did the hard reset work for you? ive been stuck on this one
из
hello, how did you solve the problem?
из
Try force restart, press and hold power button and Home button at the same time about 10s until you see an Apple Logo then release it.
Оценка 0
I tried using 3U tool to restore my 6s from Recovery Mode. Screen with apple Logo Started flashing (@ 2-3sec per flash). On & OFF .. it is just going on. Nothing is working.
Status is also started showing “Not Connected”
When i remove the Lightening Cable from the phone, it just shuts Off Instantly.
Any Advice / suggestions ..
Regards
Оценка 0
4 Комментариев:
DFU recovery!!! search up videos on youtube
из
you may have to attempt it a few times. Ive seen reviews of people needing it upwards up 3 times before it works. It will erase ALL data, just make sure its backed up
из
из
exact same problem, has anyone found the fix?
из
I litteraly have this same problem and its so stressful, my computer wont charge it at all & only turns on and goes into boot loop with wall charger
Оценка 0
sometimes this logo loop issue in iphone is due to harware problems.. for example now i have a phone that has the same problem and I tried to charge or update it using itunes but it gives error(9)… I heard from my friend that he had the same issue and told me it may be from a crash in charging module located inside the phone responsible to control lightening electrical parameters. I guess the previous owner of my phone has used non-standard chargers
Оценка 0
Добавьте свой ответ
CGSK будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 26
За последние 7 дней: 145
За последние 30 дней: 638
За всё время: 31,359
