Дата выхода 25 сентября 2015 г. Модель A1688 / A1633. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 16, 64 или 128 ГБ памяти; в цветах: Серебристый, Золотой, «Серый космос» и «Розовое золото».
2695вопросов Показать все
Why did the new IFIXIT battery swell up in less than a year?
I ordered a replacement battery kit from IFIXIT for my iPhone 6S in April 2023. The installation went OK and the instructions were easy to follow. The phone had some use after the new battery was fitted, but recently has been mostly idle. It was left switched off for a while, then connected to power to re-charge. I now find that the battery has swelled a lot and is bending the screen outwards by about 5mm. Is is usual for the IFIXIT battery to fail so soon?
in friendship
Rowland
Это хороший вопрос?
Оценка 0
2 Комментариев
Sounds like something you can take up as a guarantee case with Ifixit as batteries are usually not supposed to fail this easily. Did you doublecheck everything at the time of installation? One minor thing like a tiny shard of glass or a tiny bit of metal shavings under the battery can cause these issues over time if it was not doublechecked and installed properly. More details about how it was stored etc would help people here give a better diagnosis.
из
Thanks Markus - as a retired electronics engineer I am usually quite careful about working in a sterile environment and avoiding foreign objects getting into the innards of anything I'm operating on, so I hope that was not the issue.
As to storage, it has been at room temperature since the new battery was fitted, with as previously mentioned, some active use and then left powered down for a few weeks or maybe a month or more, then put on charge and left unused.
I haven't yet seen any obvious way to claim under guarantee but will poke around more on the IFIXIT website.
in friendship
Rowland
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
@rowland28774 iFixit offers 1 year warranty on their batteries The iFixit Guarantee It may have been the battery but things like this can also be caused by issues with the charging circuitry and the power management IC
Anyhow, iFixit will always make things right. that is why we are still here :-)
Repair is War on entropy!
Был ли этот ответ полезен?
Оценка 2
2 Комментариев:
Thanks for the link - not sure why I couldn't find it first try. Have now initiated a guarantee claim by e-mail
из
You may have gotten unlucky, faulty batteries do exist!
Good luck with your new one once you get it, my friend.
из
Добавьте свой ответ
Rowland будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 10
За всё время: 40
