Guides for shoe repair and maintenance, keep your pair of foot apparel in pristine condition.
36вопросов Показать все
How can I repair a hole on my shoe sole?
I've had a pair of leather Skechers shoes for years. Over time, one of the shoe soles developed a quarter-sized hole through wear and tear, and I had to throw the shoes away. I purchased another pair of the same shoes, and now they're developing the same hole after being used for a couple of years.
The rest of the shoes look fine. Is there a viable way to repair the soles so that the shoes can last another couple of years?
Это хороший вопрос?
Оценка 6
Добавить комментарий
12 Ответов
Выбранное решение
I used to have shoes resoled at a local cobbler. Cost a fraction of buying new shoes and made the old shoes feel brand new. But this site is called "i" fixit -- so here's a link from howstuffworks.com that describes how to resole shoes yourself: http://home.howstuffworks.com/how-to-men...
Был ли этот ответ полезен?
Оценка 11
1 Комментарий:
Awesome... thanks!
из
Another great for rebuilding the soles of your shoes is "Shoegoo Adhesive" which can be found at your local walmart, target, homedepot etc. It comes in a red foil tube and is made by Eclectic Products.
Оценка 3
1 Комментарий:
ShoeGoo is amazing stuff. I am always shocked and impressed with just how well they re-glue parts of my shoes that come un-glued. Key thing is to apply the glue, then weight it down for 24-48 hours. Especially with rainy weather, it has helped me save and repair many shoes.
из
I have noticed that even good brand shoes will start to separate their rubber or plastic sole for me at the toe. I use Shoe Goo and lots of clamps for 24 hours. Eventually it might start to pull away again, and I redo it. Not the greatest but extends the life well beyond normal, since all of my shoes come from thrift shops and are already pre-loved.
I don't think in this consumer age things are meant to last, so I override that in most cases because usually I am crazy about the design. Birkenstocks are the only product I usually don't have to mess with, but I have even glued one pair that was about 10 years old.
Оценка 3
1 Комментарий:
I just emailed Blundstone Canada, because, I was dismayed to read on their website FAQ, Blundstone states: "Once you've worn through the outsole of your boots it's time to replace them. Blundstone outsoles can't be repaired. "
This is completely incorrect.
I did a search of resoling Blundstones and have found a number of cobblers locally who will resole them.
In 2021 with our Climate crisis, I found this very irresponsible. Australia had some of their worst fires in history last year. Billions of animals, including koalas and kangaroos died very painful deaths.
All manufacturers should be making their products repairable.
I really hope Blundstone becomes a better corporate citizen.
из
Sounds like normal wear and tear, a simple solution would be to just replace the soles, as the rest of the shoe is fine.
As for repair- there are kits to repair soles, however usually they're meant for quick fixes and not to be lasting repair, some searches can show you a few:
http://www.google.com/products?hl=en&sou...
however as stated before, these are usually just for quick crude fixes.
Оценка 2
if they are plastic / rubber soles
try a puncture repair kit from a bicycle shop
Оценка 2
There is a product just for this purpose ! It was "Bison Marathon", it then became "Bison Liquid Sole", and I think its now called "Bison Liquid Rubber". (Don't they love confusing us ?)
It flexibly fills the hole, and extended the life of a pair of my particular favourite shoes for a couple of years. Make sure the worn part of your shoe sole is as clean as you can possibly make it before applying. If the hole is right through, duct tape the inside first. Their web address is www.bison.net
A similar product is "Shoe Goo"
Try Googling these names for hardware stores in your area.
Оценка 2
1 Комментарий:
That ShoeGoo product is by far the best solution for this problem, as it only takes a few minutes to apply the fix, and there's enough in the tube to last you for other, future repairs (note that the actual "ShoeGoo" brand name product doesn't come in the biggest tube, but there are other, near-identical products sold under different names that do come in larger tubes … as long as it's "goopy" and includes the word "rubber" in the "works on" section of the text on the tube, it's fine). If the hole in the sole was caused by regular wear, you'll find that other, future shoes will tend to wear in the same way and get holes in the same approximate spot, at which time you'll be glad you have that tube laying around.
из
I've had "walking" shoes with a supposed "1000 mile wear guaranty" delaminate or separate from the upper or wear through the tread in less than 100 miles of casual walking on concrete sidewalks. Rather than go through the hassle of getting the manufacture to honor the warranty and pay for return shipping, I repair separations and delamination with Gorilla Glue.
The normal lifetime of a modern casual shoe with a non-leather sole is generally less than 1 year of actual use. Composite soles with a tread and a foam midsole wear the fastest, rubber lug block soles somewhat slower. Soles stitched to the upper using a Goodyear-type welt , and vibram-type molded soles can be replaced, but may cost more than a new pair of shoes.
Tread wearout is very annoying if the upper and lining are still in good shape.
If you have a hole, try using McNett Freesole. Thoroughly clean and roughen the surface with sandpaper and lighter fluid or naptha and applying it in an even layer that extends 1" beyond the hole in all directions. Allow to dry for 48-72 hours, then use a sanding block to feather the edges.
PS If your shoes consistently develop holes in a particular location, rather than wearing evenly across the width of the sole, then that is a pressure point, and the best "fix" is prevention, not repair. A rigid shoe insole insert combines with an off the shelf insole will help distribute the wear more evenly.
Оценка 2
2 Комментариев:
That was the most useful answer.
из
why does Bison liquid rubber cost $25 for 2oz. While shoe goo costs $6? Is the Bison much better qulity? Will shoe goo hold up fixing a hole in the sole?
из
How about gluing a piece of leather to the area with shoe goo and then adding a little more shoe goo on top? that will give it a couple weeks extra life.
Оценка 1
1 Комментарий:
A bad sole repair will cause blisters that can become infected. How much are your feet worth?
из
Why not try using a bicycle tire repair kit?
Оценка 0
Has any one used JB weld?
Оценка 0
3 Комментариев:
Did no work!!!
из
too brittle ... you need something that is pliable that will "give" when you walk; otherwise it will snap open eventually. shoo goo is such a product, and there are knock offs of it available if you compare ingredients.
из
I used JB Weld. After it dries, I cover it with Shoe Goo.
из
Orthofeeet shoes Recommended by a close friend who has used your product for years with immediate relief. I hope I am able to say the same when I start using them. My foot pain is becoming unbearable. Shopping experience was effortless. Shopping & placing order was easy. Will be waiting to see the quality of product ordered. I have a very small foot, size ladies 4, some size 5's fit if they run small/narrow, which is hard to find. I have high arches & have to have good support shoes. Hoping these orthotic arches will help in my sandals.
Оценка 0
As s retired shoe repairman I can tell you with fact that do it yourself shoe repair is not a good idea. Trained experienced shoe repairman are the best answer. They are professionals and have the right products equipment and most of all the knowledge to fo the repair the right way.
Оценка 0
1 Комментарий:
I have found NO professional repairmen that will work with plastic composite soles. This is why we are resorting to DIY.
из
Добавьте свой ответ
Miroslav Djuric будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 10
За последние 7 дней: 27
За последние 30 дней: 121
За всё время: 258,869
