Battery will not charge, what is the problem?
Just replaced battery ( thinking this was the problem ) but no success, so, replaced hard drive as well in my iPod classic 20GB. Now it won't start up or charge at all, plugged it in to my PC and it was recognized said to restore which i did, was then asked to plug in to charger to finish restore but nothing happens when i do this. Anyone got any ideas what the problem is ?
Это хороший вопрос?
2 Комментариев
Hi, I too have the 4th Generation iPod & replaced battery but my port has come off & now unable to use. The ports that suppose to replace has ears & mine does not! Where can I purchase the correct port?
из Carmen D Valdez
i SOLVED THE 'NOT CHARGING' ISSUE BY USING A 10W USB APPLE CUBE CHARGER. THE 4TH GEN CLASSIC SHOULD CHARGE ON A USB CUBE BUT MUST NEED 10 WATTS.
из JohnS
