Обновленная версия iPhone 3G с более высокой скоростью обработки. Ремонт этого устройства схож с iPhone 3G, и требует простых отверток и инструментов для вскрытия. Модель A1303; 16 или 32 ГБ памяти; с Черной или Белой задней пластиковой крышкой.
1500вопросов Показать все
Вопрос закрыт
iPhone won't charge. "This accessory is not supported"
Hi everyone. My iPhone 3gs won't charge fast enough.
Every time I plug in my iphone 3gs to charge, it keeps getting the error message: "This accessory is not optimized for this iPhone". And even when it does charge, it will have that message, and it takes 30 minutes just to charge up 5% of the battery
What I have done=
-Replaced Charging port 2x with brand new parts (Mengtor & Wireless parts inc)
-Cleaned the board and all chips and possible connections with isopropyl Alcohol.
-Used many MANY different chargers (Wall, Car, Docks, Firewire, etc etc)
-Hard resets
And none of them have worked!! Any help guys?
Это хороший вопрос?
Оценка 0
2 Комментариев:
Have you tried a new Apple sync cable? I have multiple cables that give me the same error.
из
The3gs is sensitive to cheap cables. I had one blow from a car charger I bought off eBay. The power management ic is prob bad. Possible to switch yourself if you feel up to the task. If not just take it to a repair shop
из
Добавить комментарий
2 Ответов
I have heard from several repair shops that the 3GS & first-gen iPad are extremely sensitive to 3rd party cables, so.. best bet is to get a new Apple sync cable.
Был ли этот ответ полезен?
Оценка 0
3 Комментариев:
I have. Bought 2 from the actual Apple store. D:
из
@Alex Nguyen, did the new cables work?
из
I second Nick27's answer. Forgot about the Power Management IC...
Seems to me that car chargers are harmful to the 3GS, unless its a reputable one.
из
Try Different usb cables
Оценка 0
1 Комментарий:
already suggested....
из
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 8,990
