Is the optical drive connector PATA/ATAPI or SATA?
On the Apple Mac Book Pro A1226,
On the iFixit Guide about optical drive replacement, there is one type of connector :
PATA / ATAPI connector
But on the iFixit Guide about dual hard drive, the solution provided :
9.5 mm SATA Optical Bay SATA Hard Drive Enclosure
offers an other type of connector.
SATA Connector
How to know which connector is the correct one on my model ?
On iFixit, there is clearly a problem because the part sold to hold the disk on the optical bay cannot match.
Unibody Laptop Dual Drive Изображение
Продукт
$24.99
Это хороший вопрос?
Оценка 2
1 Комментарий
Just to clarify things here: Depending on your model of system (iMac or MacBook Pro) you could have a PATA (ATAPI) optical drive or you could have a SATA optical drive (newer systems). The HD carrier used to replace the optical drive holds a SATA HD in either case and converts the I/O in the older systems to connect to the PATA interface. In the case of the newer carrier it does not convert the I/O as it's not needed. Sales is looking at clarifying the description so this is clear between the carriers.
из
Добавить комментарий
1 ответ
Выбранное решение
Hi Hugo,
This is the enclosure that you need:
[связанный продукт отсутствует или отключен: IF107-078]
You can verify it by checking your system info under Hardware>ATA . I have a A1226 as well and im sure that it is ATAPI and not SATA.
Well spotted
Был ли этот ответ полезен?
Оценка 1
4 Комментариев:
Good catch I've notified the sales group so the products can be verified and descriptions can be corrected
из
I've edited the optical drive replacement guide, now I'm just waiting to see if they approve it.
из
Jay which guide did you post the correction to?
из
Добавьте свой ответ
hugo будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 4
За всё время: 6,623
