itunes error -1 cannot restore in itunes
Hello my friends i have a challenge for you !!!!
i have recieved an iphone 4 after water damage
turns on ,cannot restore -first got the error 23
then i REPLACED the PCb in a good known full iphone case with ,stll the same error
board corosion =pass
btry replacement =pass
there seems to be a defected or eaten coil right benith the baseband chip from what i see it has been fixed ,but still issue remains =cannot restore ...i get error -1
which means a hardware issue or baseband
the baseband chip & its connection seems to be fine or at least looks fine on the board
the restore almost reaching 80% and then hangs and then stops !! with error -1
i would very much apprichiate your help on this one!!!please!!!
Это хороший вопрос?
ok =fixed it ! for now ,,,,but the camera is bad =white noise ,after replacement = still no flash!!!!
what should i do ?
из 7Gnosis
how do you fix -1 error?
из zoltanboltan
How did u fixed the error-1
из bobby74521
