Released on July 21, 2011. Core i5 or Core i7 Processor. Thunderbolt. This unit is also used to run the Mac mini Server configuration.
204вопросов Показать все
Any SSD size limit, can 2 large SSDs be installed?
Hi,
I currently own a Mac Mini Server 2011 edition which came with the 2 HDD 7200 drives, factory pre-installed drives. I want to replace both of them (or at least one of them) with SATA-3 type SSD drives of either 480 or 512 GB capacity.
I wanted to ask if anyone know if this is possible without issues? I plan on using both Mac OSX Lion & Windows 7/8 with Bootcamp option.
Thanks !
Это хороший вопрос?
Оценка -1
Добавить комментарий
1 ответ
Выбранное решение
As far as capacity there is no restriction. Your SSD's need to be 2.5" drives to fit in the mac mini.
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
Jay - Mac Mini uses 3.5" drives so the SSD could be 3.5" Vs 2.5" which could also fit with a sub frame & adapter SATA to CD or ZIF to support them.
из
Добавьте свой ответ
talalcheh будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 651
