My Webcam is not working. How can I resolve it?
Actually, this laptop is not mine. And this HP Pavilion dv6000 comes with Windows Vista by default.
My brother replaced it with windows xp. and since then the web cam is not working.
I guess its the drivers problem. But I'm unable to find the xp drivers for this laptop.
How can I resolve this.. Please help :(
Thanks in Advance :)
Это хороший вопрос?
Оценка 3
1 Комментарий
i had the same problem reset the computer does not work its a software problem just contact hp http://goo.gl/kF8xku and they will help
из
Добавить комментарий
3 Ответов
Наиболее полезный ответ
It does sound like drivers. does this link help?
http://h10025.www1.hp.com/ewfrf/wc/softw...
Был ли этот ответ полезен?
Оценка 1
my laptop web camera not working ,so i was swap the new motherboard ,web camera and installed new web cam drivers and also but i unable to work webcam.so give me solution
Оценка 0
Hi Dear
Refresh driver from device manager. (Device manager > Expand Imaging Devices > HP Truevision HD Webcam) then you will find the solution.
if still it will not been resolve
Check in UEFI - F2>Component test> Webcam > Run Once( for uEFI test you can check via power on your laptop and press F2 key you will find UEFI page then please perform Webcam hdd test if its failed please conatact to HP service center.
Оценка 0
Добавьте свой ответ
Shoyeb Sheik будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 2
За последние 30 дней: 9
За всё время: 3,731
