Why is my phone not charging?
when I connect the charger to my phone it does not charge, but if I bend it back and forward, it is really rare it will charge.
Это хороший вопрос?
Это хороший вопрос?
Angela Molina, if the "bend it back and forward" shows some results, it does sound like a bad charging port. Start off by using a new cable and see if that makes a difference. It is possible that the plug on the cable end is worn out. If it does not, you may have to replace the charging port. Take a look at the teardown and see if that is something you are comfortable with. You will have to solder a new connector to the board. The port is available at places like this. Hope this helps, good luck
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 5
За всё время: 11,128
