PC laptop by Dell with a 15.4" display. Succeeded the Inspiron 1520.
Laptop not turning On when pressing power Button
When I press on Power Button only the media player touch LED blinks once and the light for caps and numlock continuously blinks even I can see power on DVDROM and fan too moves . But none of the LED in front blinks and no power on monitor is there.
Could you please suggest me what should I do.
Это хороший вопрос?
Счет 2
2 Комментариев
can you attach an external monitor and see if you get anything? Any post beep's?
из
Use this : Dell AC Adapter LA90PM130
из
Добавить комментарий
2 Ответов
Выбранное решение
Thanks for your Suggestion "oldturkey03"
I have troubleshooted it and found the reason, its because one of my RAM has gone Bad.
Regards,
Amit Lal
Был ли этот ответ полезен?
Счет 0
Some times the Heat sink & fan gets dust and due to which system gets heated.
Once cleaned can help overheating & abnormal switching off issue.
Счет 0
Добавьте свой ответ
Amit Lal буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 4,079
