The Power Macintosh G4 is series of personal desktop computers released by Apple in 1999, and sold through 2004. This page is for the M5183 designation.
39вопросов Показать все
Вопрос закрыт
How to recover files from hard disk?
I have a functioning hard disk from a G4 Power Mac. When I connect it to my Macbook Pro (OSX 10.8.2) via a Universal Drive Adapter it doesn't appear in Disk Utility or Finder. Anyone know how I can get the files off this disk? The disk has a jumper in the left-most (out of 4) positions. Do I need to move or remove that?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Which universal drive adapter do you have? Some older drives need more power to operate and need the power cable connected. If you drive adapter has an ATA data but not power connector then you may need to get a different one. If it just runs off a USB port and nothing else than you will likely need a new one that can supply power. What does your hard drive do when you plug it into your current adapter? Does it click, make noise, and/or vibrate? You might also have a hard drive issue. Get back to us.
Hope this Helps
Был ли этот ответ полезен?
Оценка 0
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 3
За всё время: 533
