How can I completely remove the screen?
I want to remove the screen from my PowerBook G4 so I can use the base as a computer attached to my TV without any loss of functionality (I understand Airport and the Bluetooth antennas are connected to the screen?) All help appreciated!
Это хороший вопрос?
Счет -1
Добавить комментарий
2 Ответов
Выбранное решение
I would follow the directions for removal of the LCD screen first as described here: PowerBook G4 Aluminum 17" 1-1.67 GHz Display Replacement
Then you should be able to remove the hinges.
Был ли этот ответ полезен?
Счет 2
You can separate your display assembly from your bottom case using the link mayer posted in his answer then open the display and remove the airport/bluethoot antenna cable. Simply reconnect the cable to your logic board and you will restore the wireless functionality.
Счет 2
Добавьте свой ответ
Dave Robertson буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 3
За всё время: 1,301
