The Kindle Fire, Fire, or Amazon Fire is an Android-based media tablet by Amazon with a multi-touch color display. Repair requires only screwdrivers and prying tools.
797вопросов Показать все
Changing the front glass of a Kindle Fire
I have seen detailed instruction on the site on how to remove and replace it. Unfortunately, the site does not provide any links on where to buy the new glass. That would be a really helpful part of the whole process. So, where does one buy the replacement glass?
Это хороший вопрос?
Оценка -1
Добавить комментарий
1 ответ
Выбранное решение
Toufigh Gordi , you can get it from places like this or from here or even from here. Do a Google search and pick a places that is agreeable with your geographical location. Hope this helps, good luck.
Был ли этот ответ полезен?
Оценка 0
3 Комментариев:
Thanks! I did search Amazon and found one. However, I think it would be nice, for the completeness of the instruction page, to have a couple of few links there. Just a suggestion.
из
It is difficult to add those to any guide, because of it being outside vendors. You never know when the item becomes unavailable, which then could lead to dead links. Also, the vendors may not be in every ones geographical location, making it useless to others :-)
из
Makes sense. Thanks!
из
Добавьте свой ответ
Toufigh Gordi будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 682
