Capturing high-quality digital images is fast and easy with this state-of-the-art smart camera. Equipped with a 14.0-megapixel CCD, this camera is capable of capturing images with a resolution of up to 4288 x 3216 pixels.
How to delete photos on camera disc
how do I delete images on camera w/o replacing disc
Это хороший вопрос?
Счет 1
Добавить комментарий
1 ответ
Выбранное решение
thomas Riley, that should be part of your menu.
"Erasing Images
Erasing a single image / Erasing all images
1. Press the 7 button.The last image appears on the screen.
2. Select the image you want to erase with the < / > buttons.
3. Press the MENU button.
4. Select [Delete] with the up /down buttons, and press the SET button.
5. Select [Single] or [All] with the < / > buttons, and press the SET button.
[Single]: Erases the selected image or the last image.
[All]: Erases all of the images except for the protected images.
6. Select [Execute] with the < /> buttons, and press the SET button.
To not erase, select [Cancel], and press the SET button.
7. To exit from the menu, press the MENU button.
The manual is available right here
Hope this helps, good luck.
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
thomas riley буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 11
За всё время: 1,487
