My iPad screen is parshly green.
You can still see my lock and home screen, but its covered in green. Any body know how to help?
Это хороший вопрос?
Это хороший вопрос?
Hi just disassemble your ipad and disconnect your lcd cable, then reconnect it back, did this happen after a fall?, most probably the connector is loose or worst its the lcd cable, hope that helps cheers!!
Был ли этот ответ полезен?
Hi have you tried the solution i suggest to you?, btw just for future use, try to tape the lcd connector point so that it does not come loose again, cheers!
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 5
За всё время: 397
