Why does my battery port works in just a specific way?
So whenever I try to connect micro usb, it only work when i hold it in a certain way. How can i fix it?
Это хороший вопрос?
Это хороший вопрос?
Dev Patel, sounds like you need to replace the USB charge port. Here is a decent video for that procedure. You can either try and find a USB port that matches, at places like Mouser.com or Digikey.com, and try to solder it to the flex, or replace the assembly with a part like this. Hope this helps, good luck.
Был ли этот ответ полезен?
Turkey is right. This is a pretty easy repair for a charge port. No soldering is required. Definetely replace the whole assembly. It is faster and gives a more professional repair.
За последние 24часов: 0
За последние 7 дней: 5
За последние 30 дней: 5
За всё время: 646
