Model No. A1367 / 8, 16, 32, or 64 GB capacity
915вопросов Показать все
power button stops working after screen installation
I just replaced the screen on an ipod. I was extremely careful with this installation, and yet now the power button is not working. I see no rips or tears in the cable. The power was off during install. Any ideas on whether there is a way to fix this without a whole new cable?
Update
Nope, no go :(
Это хороший вопрос?
Оценка -1
1 Комментарий
I only get the voice control coming up when I try that. I just had it happen again. Power button working fine. Now not. I used plastic tools for all the areas around the power button, so I don't see how it could short out. This is REALLY maddening.
из
Добавить комментарий
1 ответ
Выбранное решение
have you reset it as sometime you can short something when you change the screen
press and hold the POWER & HOME buttons wait till it turns off keep them pressed till it comes back on this should get it out of safe mode
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
I'll give that a try and see if it works!
из
Добавьте свой ответ
Heather B будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 609
