iPod touch 3g will not turn on what will I do
my apple ipod touch 3g it has just gone blank i was downloading a song off itunes and it just went blank i thought it may of ran out of batery so i pluged it in and not eaven the charging thing came up when i held the power button what should i do try and fix it or buy a 5th gen
Это хороший вопрос?
Оценка 1
1 Комментарий
Does it charge ? If not, have you tried a different cable ?
из
Добавить комментарий
2 Ответов
Выбранное решение
conor, try a hard reset first. To reset the iPhone or iPod Touch, press and hold down the Sleep/Wake button and the Home button at the same time for a minimum of ten seconds, then the LCD display will clear and the Apple logo should appear on the black background. Once the logo appears, your iDevice is reset.
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
But what if that doesn't work?
из
Your charge battery could've run out of charges
The charge battery has a limited amount of uses until it needs to be replaced
Оценка 1
1 Комментарий:
Ryan Ckit, why does it remain lifeless when it is plugged in? How do you suggest to fix it?
из
Добавьте свой ответ
conor будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 1,722
