All-in-one desktop computers from Apple. iMacs were equipped with Intel processors from 2006-2021.
7455вопросов Показать все
Data Transfer between iMac with faulty logic board and new iMac Intel
Trying to transfer data from a G5 with a faulty logic board to an iMac Intel fresh out of the box. I attempted this once by removing the front panel and using a multi imput bridge connected to the faulty iMac hd to a USB connected to the new Intel. Copied files, but they are just images. My question is, will Migration work with just one fully working computer, and if so, will I need a firewire? Or is there a way to bridge the two and fully transfer data over the bridge cable?
Это хороший вопрос?
Оценка -1
Добавить комментарий
1 ответ
Выбранное решение
Yes it will work from one good machine. Remove your old HD and put it in an external case. (Since new machines can boot via USB you don't need a firewire connection) Connect that to your new machine... you can use Migration Assistant to move the entire contents (including account) to your new machine.
If this Answer is helpful please remember to return and mark it Accepted.
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
Thanks so much...answer was exactly what I needed. Migration went off without a hitch.
из
Добавьте свой ответ
Ryan будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 250
