CDMA версия четвертого поколения iPhone. Ремонт прост, но дисплей должен быть заменен в сборе с сенсорным стеклом. 16 или 32 ГБ памяти / Модель A1349 / Cовместимость с CDMA.
295вопросов Показать все
Вопрос закрыт
After taking apart my Power button it wont click anymore?
Hey ,
So I recently purchased a used midframe with parts from ebay
everything worked but the power button would not click so I toook the two screws which held the button in place and i couldnt figure it out
So i did the same to another midframe I had which did click to see any diffrence
After putting the one the clicked back together it refuses to click
its just like the one that didnt click and I cant figure out whats wrong with it
the black dot is there and I followed the guide on ifixit and it WAS working
Someone please help me
thanks alot
Это хороший вопрос?
Оценка 0
1 Комментарий
When you use the Pwr button, even though it doesn't click, does it work like it's supposed too ?
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
screws could be too tight
Был ли этот ответ полезен?
Оценка 1
I just replaced a power/lock button on a friends iPhone, and I can 95% guarantee you that you have the screws too tight. The screws on an iphone should be hand tight for the most part. Try removing the internals again and leaving the power/lock button installed. Now back the screws out in small increments. This should illustrate that loosening the screws will allow the button to operate.
Оценка 1
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 3
За последние 30 дней: 3
За всё время: 883
