Пятое поколение iPhone. Ремонт данного устройства простой и требует только отвёрток, лопатки для открытия и терпения. GSM/CDMA / 16, 32 или 64 Гб / Черный или Белый.
2193вопросов Показать все
Вопрос закрыт
Power Button does not work after flexcabel change
first off all i'm from switzerland. sorry for my bad english. 2 months after guarante my power button get stucked. it doesn't made click anymore. so i changed the flex cable including sensor. after the repair the power button clicked, but didn't work. the sensor didn't worked either. then i bought another flex cabel incl. sensor (a better quality).
and now the sensor works but the power button doesn't. It clicks but there is no reaction.
does anybody had the same problem?
im thankfull for every answer.
regards from zürich
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
It seems that you have to change it again...
[связанный продукт отсутствует или отключен: IF182-004]
iPhone 4 Power & Lock Button Replacement
iPhone 4 Power & Sensor Cable Replacement
If this answer was helpful please remember to mark it accepted.
iPhone 4 Power & Lock Button Изображение
Инструкция
Сложность:
Сложно
15 - 30 minutes
iPhone 4 Power & Sensor Cable Изображение
Инструкция
Сложность:
Сложно
1 - 2 hours
Был ли этот ответ полезен?
Оценка 1
5 Комментариев:
sorry my mistake. i meant of course the power button (not home button). same answer? thx in advance
из
Answer corrected... ;-)
из
hello xgonin
thx for your update.
i replaced it now for the 3rd time.
and the power button works now. but..!! :(
the sensor works now backwards.. when i put my hand on it, the display appears and when i put my hands away, the display disappears.
do you have a solution? thx in advance. regards from zürich
из
i repaired the phone for the 4th time with another new flexcable. now its working well. failure was 3 not working felxcable. thx for support
из
you're welcome ! ;-)
из
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 3,179
