Hi Igor,
Luckily it looks like a software issue and not hardware!
First try to turn of your devise, remove the battery and wait a few minutes and plug it in again. Try to see if it's work now. I had a kind of similar issue in the past with my Nexus S and it have fixed.
If not better, you should try a hard reset. The only issue, it will delete all information on you internal storage (SMS, MMS, Call log, settings,apps...) but probably not what you have on your memory card (Picture, Music,...).
If you want to do so and don't care about internal storage information follow these steps:
- Have your battery fully charged.
- Turn OFF your cell phone if you can.
- Remove the battery and way a few second.
- In the mean time you can eventually remove your SD card so that you can be sure nothing will be deleted on it.
- Plug it in again.
- Press and hold both Volume up + Power button at the same time.
- Use volume Up and Down to navigate and select "Factory reset".
- Validate with power button.
This will hard reset your phone and I hope fix the issue. It may take a 10-15 minutes!
Keep us updated. Good luck.
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
12
Отмена
Scroll through this thread to find the appropriate place for this comment. Then, click "Attach comment to this post" to move it.
11 Комментариев
Nope, i got phone in May and i it was working normal.
из Igor
my huawei behaves like a laptop only works when pluged in power socket............!
из Rhamzan Shakim
How to fix my huawei it really won't turn on even if I already press the turn on button...please help me..
из angel
hi I have it on my hornor 4x model:che2-l11 color black all black I get this in Christmas last year & I still have the problem unfortunately, Huawei Home has stopped & I can only fabrication it & can't not back-up it after I fabricator it be the same as I get it so is it the sd-card intern harddisk or is it my problem to install crap I do this almost every day & I hate it be like crap so what can I do honor Huawei 4x is with 2 sim-card 1 sd-card no battery to tap out & every time I get on to the mobile I need to download the games or app over again & it take me lots of hours no Wi-Fi I can't no use please can someone E-mail me on notfake2001@hotmail.com to support how I can do to not have this problem & I told your I'm sick of fabrication it over 15 times on 2 month
из Christian no last name
Is Che2-L11 hornor 4x color black
Показать 6 больше комментариев
