Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
Stripped Screw on the Logic Board
I was trying to get the motherboard out so I can replace the thermal paste on the heat sink on the other side, and the last screw in the logic board became stripped. The screw is a 3.9mm screw. I was using a #00 Phillips head screwdrver. It is in the lower left-hand corner. I have a photo of it, but am not sure how to add it here.
What is the best method to take this out?
Это хороший вопрос?
Счет 1
3 Комментариев
I will have to get an extractor set - thanks!
I am not sure where the dropbox is :-/
I read through the list and tried the rubber-band and plier method. The screw is unfortunately too small for pliers and the rubber band didn't work. I have no drilling or rotating tool experience (dremmel), and don't have the tools themselves. Also, if I use JB Weld, the screw grooves will be permanently filled in, so that is an option but I am trying to see if it can be gotten out without permanent measures first.
I also tried taking it to the Genius bar, but was refused for liability reasons (although I know some others have been successful at having stripped screws removed by Apple).
Not sure what to do at this point, will probably have to try the extractor set and if that doesn't work, to find someone local who can take it out.
из
I just wanted to thank everyone for their advice. I ended up trying the suggestions xgonin posted, but could not get the screw out myself. A friend helped me extract it by sodering another screw on top of mine.
из
I had to drill the screw head off of several screws. After removing the fan and logic board, I was able to grip the remaining studs with needle nose pliers and extract.
из
Добавить комментарий
4 Ответов
Наиболее полезный ответ
I use the Precision Screw Extractor Set for this type of problem:
\Precision Screw Extractor Set
Four different sized extractor tools to help remove fasteners or screws with stripped heads. Driver head is claw shaped for maximum grip. Sizes range from 1.1mm to 2.0mm. Изображение
Товар
$24.99
Был ли этот ответ полезен?
Счет 4
4 Комментариев:
I want! Had a side screw in an iPhone 4 the other day that got stripped. I see I need this set on my bench, thanks for posting mayer!
из
Bought this and tried it. Complete waste of time and money. Don't bother.
из
Huh...my set worked! I guess it just depends on how it's stripped, but that's situationally dependent and hardly justifies calling them a "complete waste of time and money". So grandiose.
из
Perhaps I should have been more clear, complete waste of MY time and money.
из
If you don't have extractors,you can try these different procedures....
Take a look at these links :
Remove a stripped screw
The 12 best ways to remove stripped screws
If this answer was helpful please remember to mark it accepted.
Счет 1
Ok, I have done the same thing and the best thing to do is use a precision file and cut a groove in it, all the way across the head of the screw and then use a flat head screwdriver to remove it. When I did this I used a dremmel with a metal cutting disk, kinda risky, but it turned out ok.
Hope this helps,
John H. Laney
Счет 0
I could not figure out how to post a pic,so I posted it to my dropbox,and made a link to it.
Счет -2
Добавьте свой ответ
Vera буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 8
За последние 30 дней: 17
За всё время: 4,069
