Home button seems to be pressing by itself?
The home button on my iPod Touch seems to be pressing by itself.
If I open any app it will just close after a few seconds as if I pressed the home button. Also, when I'm not in an app it will just flip back and forth between the search screen and the list of apps as if I was pressing the home button.
The button does not seem to be physically jammed because when I do press it you do feel and hear it click. And the button does work.
One other note..if I press down either to the right or left side of the home button it does act as if I did press the button.
Any ideas on this? Thanks.
Это хороший вопрос?
Счет 1
Добавить комментарий
2 Ответов
Наиболее полезный ответ
If this is a 3rd generation Touch, I'd take it back to Apple, as it should still be under warranty.
Был ли этот ответ полезен?
Счет 1
did you find a solution? myn is doing the same.
Счет 0
1 Комментарий:
Edited to remove email address (for security reasons
из
Добавьте свой ответ
Keith Maurino буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 4,193
