Optical Drive hardware eject
I have an A1261 Core2duo 17" MacBook Pro which died due to a faulty logic board a few days ago. There's a dvd stuck in the drive which I want to get out. What are my options? It's out of warranty, so I don't mind tearing it down. Is there a hardware eject for the optical drive?
I'd also like to know if you guys stock logic boards for my laptop model... its a 2.5ghz core2duo 17" mbp
Это хороший вопрос?
Оценка -1
Добавить комментарий
1 ответ
Выбранное решение
Here is the guide for opening a drive to remove a disk. You must first remove the drive for the computer. I'm still looking for that guide for your computer. Ralph
Optical Drive Disc Removal Technique, or Foreign Object Removal
The best I can fin is the 15" MBP but it should give you a good idea. Ralph
MacBook Pro 15" Core 2 Duo Model A1211
Был ли этот ответ полезен?
Оценка 3
2 Комментариев:
The right link +
из
Thanks for that. I got the disk out using the credit card trick :) didn't actually think it would work, but it did :P thanks anyways
из
Добавьте свой ответ
Nikhil Venkatesh будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 1,858
