Canon's third iteration of their long-lens point-and-shoot camera design. Originally released in February of 2006.
27вопросов Показать все
getting message to change the batteries after doing so
I used the camera less than a month ago. Now getting the message to change the batteries and have done so with NEW ones. Powers up ok, but after trying to take pic, gives the change batteries message. Have cleaned the "terminals" on the battery compartment door and have taken out memory card and reinserted.
Это хороший вопрос?
Оценка 1
4 Комментариев
Have you tried a different set of new batteries? What type of batteries are you using?
из
Duracell - and I'll try another set of new ones and keep my fingers crossed!
из
nonees...... can you please tell me if it worked; I tried it on mine but no luck.
Thank you.
из
I tried this one on mine but still didn't work, is there any other solutions to this issue?
из
Добавить комментарий
6 Ответов
Выбранное решение
nonees, the issue here could be your battery compartment door. Make sure that it makes good contact as well as the bottom contacts. If it does, and everything else checks out, replace the RTC ( 'date/time') battery. Even if your regular batteries are fully charged and are making good contact etc, if your RTC battery is discharged, it won't make any difference, and you can get this error message. That battery is in the same compartment as the regular batteries, on the opposite side of the hinge. Extract it with a fingernail, it is situated on the left hand wall of the battery compartment (when the camera is inverted and the compartment open). It is a coin type battery CR1220 Hope this helps, good luck.
Был ли этот ответ полезен?
Оценка 4
4 Комментариев:
OldTurkey03 - thank you for the clue about the RTC battery! I'll have to pick one up at the store but I bet you have solved the problem! I'll be sure to let you know - thanks again! nonee_s@yahoo.com
из
Cleaning off the RTC battery also fixed it!!!
из
I just replaced the RTC battery, and it still does the original problem. Any other suggestions?
из
AyoItsAbby what is your original problem? What make and model camera? What else have you tried?
из
Hi not sure if it would help, try taking the batteries out from the camera and leave it out of camera for a few hrs (2 maybe?). While waiting, try to power on the camera the normal way to discharge any possible remaining power. Then, reinsert the batteries back into the camera and power on to see if it helps.
Some machines somehow needs a full discharge to 'help erase' issues it has and encountered and to restart afresh.. Not sure the terms are correct but thts how i learnt over the years.
Hope the above helps! Good Luck! :)
Оценка 0
2 Комментариев:
Tried your suggestion, but same message - change the batteries..... may have to send to Canon to fix
из
can someone send a picture of where the rtc battery is on the camera
из
Canon PowerShot SX220 HS in many cases is displaying the error message "Change the battery pack" although the battery is fully charged. One solution to this problem is to add some element (paper) between the battery and the battery door to ensure better electric contact.
http://dubaibuildingsforsale.com
Оценка 0
1 Комментарий:
Don't understand how can putting paper between the battery and the battery door imorive the electric contact?
из
Would also suggest testing/ replacing the memory backup battery which is located under a flip out cover on top left side of SX120IS. It is a CR1220 button cell and generates a replace the batteries error even with fresh batteries. If you don’t have a battery tester just pull out this battery and try starting up the camera with fresh AA batteries. If the CR1220 is bad the camera will now start up in picture taking mode.
This seems to be a common error message on a number of older Canon PowerShot cameras especially ones that use AA batteries so worth checking to see if the memory backup is bad and you get this error after putting in a fresh battery.
Оценка 0
If you don’t care about the time/date staying between power cycles I was able to just remove the little cr 1220 battery entirely to get rid of the error.
Оценка 0
Canon PowerShot A630. I removed the Memory card and reformatted it. It seemed to fix the “change the batteries” problem for now…
Оценка 0
Добавьте свой ответ
nonees будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 14
За последние 7 дней: 67
За последние 30 дней: 286
За всё время: 23,951
