Released October 2008 / 2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duo Processor
376вопросов Показать все
IR sensor does not work and I need to replace it. How?
Ok, so my IR sensor does not work and I need to replace it but can neither find the part here or instructions how. There is a description for the earlier MacBook Pro but not mine, the MacBook Pro 15" Unibody (Late 2008, Early 2009.) Help!
Yes, I have already checked the Security System Preference and made sure that it will accept IR, and that it is not paired with another remote.
Yes, I made sure the remote was working (I have 2 and used the iSight camera trick to see if it was working)
Yes, I checked System Profiler and made sure under USB that the Mac recognizes that it has an IR Receiver.
YES I have already reset the PRAM.
and YES I even ran a command line program called "iremoted" that listens for button-press events and prints the identifier (the HID element cookie, to be precise) of the button in question.
for example... (not my results)
$ ./iremoted
0x16 pressed
0x16 released
0x17 pressed
0x17 released
Since it is not recognizing any button presses, I'm assuming my IR Sensor is fried.
So, where does that leave me? Well, without a working IR Sensor and a need to replace it, but cannot find the part online or instructions how to do it.
So, any idea where I may find a replacement?
Это хороший вопрос?
Оценка -1
Добавить комментарий
3 Ответов
Наиболее полезный ответ
Is this what you're looking for?
http://www.PowerBookmedic.com/xcart1/pro...
Был ли этот ответ полезен?
Оценка 2
4 Комментариев:
Nice research + Ralph
из
Unfortunately no. That's for the 13" and I own the 15".
из
Unfortunately not. That's the MID 2009 model only, not the Late 2008/Early 2009 model as I indicated. Difference is that model eliminated the expresscard port in favor of compact flash card port. Internals slightly different when it comes to this part.
из
Okay, this is definitely a very old question. Looks like it never got answered, so here it is. :-) Buy the part from here Good Luck and I am sure you have your MBP fixed by now.;-)
Оценка 1
Here's a link to what looks exactly like the ir sensor in my 2007 MBP 15" a1226. I got this link from a guy on apple.discussions. I couldn't find anything...I know this post is old, but my link works as-of 2 minutes ago...
http://www.pchub.com/uph/laptop/68-90479...
Оценка 1
Добавьте свой ответ
Sean X Cummings будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 2,292
