Model No. A1367 / 8, 16, 32, or 64 GB capacity
915вопросов Показать все
Removing old solder when replacing speaker
I broke the blue and red wires when replacing the screen, The red one broke off the board and the blue one didn't. The wires are still sticking out enough on the speaker to use them. My question is do I need to desolder the solder from the board it connects to? Someone mentioned in another post that you can solder these wires to the top of the board instead of the bottom where it previously was. There are two gold contacts on the top of the board directly on the opposite side of where it previously was soldered to. I know the solder is conductive but is it okay if i solder the wires on top of the old solder?
Thanks in advance!
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Выбранное решение
Just tin the two wires and solder them back. If there is too much solder just use a braid and a bit of flux to remove it.
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
How do you tin and why?
из
It should be ok but you shouldn't need to put more solder on the board, just heat the old solder up and stick the wires in wile its still melted.
Hope this helps,
John H. Laney
Оценка 0
Добавьте свой ответ
Christa Bahr будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 4
За всё время: 368
