Released on July 21, 2011. Core i5 or Core i7 Processor. Thunderbolt. This unit is also used to run the Mac mini Server configuration.
204вопросов Показать все
Mac mini not powering on
Hi
I've got a mac mini mid 2011 from ebay and it doesn't power on. I'm testing the power supply and following the guide, I should have 12V checking the two outer pins. When the power cable is connected I got that voltage but as the time pass, the voltage decrease going to 0V.
Is this behaviour normal ? or is the power supply defective ?
for instance, the power supply installed is an oem from delta electronics 614-0503, not a 661-6085.
Has anybody have experience with those power supllies ?
thanks
Daniele
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Выбранное решение
The power supply should be Part Number: 661-6085. But the 614-0503 is also listed for this machine: http://www.techrepublic.com/photos/crack...
It's very common to have more than one parts supplier. I think either one will work for your replacement.
Был ли этот ответ полезен?
Оценка 3
1 Комментарий:
thank you for the answer.
But Is power supply's behaviour normal ? or is it defective ?
If tried even to put a resistor in order to have a load on the output and the voltage decreased faster.
из
The behavior indicates a failed power supply; the supplied voltage must not sag too much. Probably a bad capacitor or something wrong with the feedback circuit in the PS; Just replace it
Оценка 0
Добавьте свой ответ
Daniele Acquadro будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 6
За последние 30 дней: 8
За всё время: 1,082
