Floor lamps are lights that sit on the floor. They are not table lamps, which are designed to sit on tables. Floor lamps are usually taller than table lamps.
non-working torchier floor lamps
I have 2 nice floor lamps I think are repairable but I'm stumped. There is no maker info or parts list. I think it's the switches but have not found replacements that will fit in the stalk iof the lamp. Are they repairable or jut chuck them?
Это хороший вопрос?
Счет 1
1 Комментарий
Post some images and lets see what you have there. They are lamps and I am sure we can find parts for it. Don't throw those out just yet :-)
из
Добавить комментарий
1 ответ
Выбранное решение
If you can't repair the switches, bypass them and add a foot toggle floor switch in the power cord. If you can't find that, then just put a rocker switch in the cord.
You might be able to replace the switch, but they are usually more robust than the socket. Check for a bent or broken connection in the socket and for damage to the cord. Check the cord tip for indications that it has a fuse in the plug. Good luck. Post images!
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Rich Haddock буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 7
За последние 30 дней: 20
За всё время: 1,091
