Repair information on hard drives or hard disks. Hard drives are magnetic data storage devices. They are used in most desktop, laptop, and server due to their low cost and high data density.
143вопросов Показать все
Can I replace the hard drive on a Mercury Elite-AL Pro?
I have a 160GB Mercury Elite-AL Pro storage solution box and wanted to replace the hard drive with something larger. Is it possible? If so, how hard is it on a scale from 1 to 10. With 1 being easy.
Thank you for looking.
Это хороший вопрос?
Оценка -1
2 Комментариев
Thank you mayer! I appreciate your help. I hope I provided you with the proper credit. Cheers!
из
yes you did, thanks
из
Добавить комментарий
1 ответ
Выбранное решение
OWC actually makes four versions of this case, all sharing the same Mercury Elite-AL Pro name. The difference is in the internal and external interfaces. Two models have the older IDE internal hard drive interface, and two models have the newer SATA internal hard drive connections.
Here is a teardown of the devices and how to update them.
http://macs.about.com/od/peripherals/fr/...
Был ли этот ответ полезен?
Оценка 2
2 Комментариев:
As to difficulty, I have torx screwdrivers, for me this is a 1 or at most a 2. Without a torx screwdriver this would push a 7.
из
Looks that way to me also--you do need the tools. + Ralph
из
Добавьте свой ответ
downdog89 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 3
За всё время: 1,380
