Вопрос закрыт
Pulled Pad and Circles battery terminal Gnd
I've managed to pull the pad twice on the far left GND pad and the 2 circles below it. Is there and location I can jump wire to ? Picture 1 is actual ipod pic 2 is from previos post but shows whats missing
Это хороший вопрос?
Оценка 0
2 Комментариев:
John, post an image with your question so we can see what you see.
из
The 2 golden pins are completely gone and the pad on top I solder to the circle golden pins and pulled them too
из
Добавить комментарий
1 ответ
Can you post a picture of your actual damage?
Everything is connected to ground so technically you can connect it anywhere just as long as you know whats ground. IF you scratch around the 2 golden pins, that should be ground but I can't tell until I see actual damage.
Был ли этот ответ полезен?
Оценка 0
3 Комментариев:
Just posted actual damage pic
из
I hate how ifixit doesn't have a way to check which threads I posted on have new comments. I'm not at work anymore, but I'll post tomorrow with the answer.
из
ok finally had some time to check wheres a ground. i found one on this capacitor circled.
http://imageshack.us/photo/my-images/194...
из
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 4
За всё время: 478
