The Dell Inspiron 910 Laptop was released in 2008 as part of the Dell Mini Series of small, portable laptops.
9вопросов Показать все
Вопрос закрыт
Fix the wifi issue?
Go to Device Manager and look at Network adapters to solve that problem how that will work???
Thanks
Это хороший вопрос?
Оценка 0
1 Комментарий
Does it show in Device Manager? Has it ever worked? Do you have a WiFi capabilities with this computer? You need to give us a bit more information.
из
Добавить комментарий
2 Ответов
Выбранное решение
Simple thing would be to check that it hasn't been disabled with the FN+2 key toggle if it was working before. Other than that I need more info.
Был ли этот ответ полезен?
Оценка 0
Apparently seems like your W-LAN card is either disabled from your network connections or may be there is some hard switch which turned off. All you need to go open network and sharing center then click view network connection to make sure that you Wireless connection is not disabled in any case it should have to be enabled.
Other way is to check on your keyboard from top F1 to F12 keys if you can see a Antenna sign on any of key then press that key by pressing Fn key together.
If the problem still persist then I would recommend you to go on your manufacturer`s website to download the latest driver and update your driver.
Оценка 0
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 1,790
