Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
418вопросов Показать все
What is the problem with my not booting MacBook?
friend gave me a black core duo macbook but it doesn't work. when the power button is pressed it boots up with a white screen and after a while has a screen with a flashing folder with a question mark on it.
Это хороший вопрос?
Оценка -1
3 Комментариев
If you can connect your laptop to an external display, please do so and see if anything shows up.
из
Adam, it doesn't boot.
из
I'm pretty sure that with the switch to Intel (I know this is true of my Black MacBook of the next generation up and my Retina MacBook Pro) came the muting of the startup chime if the speaker volume was muted at shutdown. So it could still be booting and just be a display issue.
из
Добавить комментарий
4 Ответов
Выбранное решение
Hello,
I think of two things:
1 - The hard drive is broken
2 - OSX system on the hard disk is broken ...
therefore:
1 - Boot from the installation DVD (DVD ready inserted and hold the "C")
2 - If your hdd detects made ​​a clean installation
3 - if it does not detect your hdd disassembled your computer and test another HDD
Был ли этот ответ полезен?
Оценка 2
Наиболее полезный ответ
Sounds like he had it lying around for awhile before he decided to sell it. If that is the case you may need to reset the SMC. Follow these instructions: Resetting the SMC. Also make sure your battery & charger are working.
Next, try an external monitor to see if the display has gone on you. And lastly, reseat the memory modules.
Оценка 2
1 Комментарий:
i've reset the smc, the pram and the nvram and now i have a white screen with a blinking question mark folder
из
Help us help you: talk to your friend and find out more about when/why it quit working. Troubleshooting works best with some history to work from.
If this answer was helpful please remember to mark it accepted.
Оценка 1
1 Комментарий:
i asked he doesn't know
из
Eldoctor is correct. Most likely you just need to reinstall the operating system, if that doesn't work you need to reinstall the operating system on a new hard drive. If you need help doing either one, message me at james@tronicstrade.com. I can send you step by step instructions
Оценка 1
Добавьте свой ответ
yben24 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 341
