The Nuvi 680 global position system features an MSN Direct subscription which provides local weather, traffic, gas prices, movie times, mp3 and hands-free calling capability, and a large touch screen color display.
7вопросов Показать все
How do I open the 680 case to replace the battery?
My nuvi 680 needs a new battery (it won't take a charge.) I have found a battery supplier. I know about batteries and can do virtually any electronic repair, but I can't find a way into the 680 case! No screws or obvious pry spots. All help welcomed. Thanks.
Это хороший вопрос?
Оценка -1
1 Комментарий
Hi, Adam, thanks for the reply. I actually found a Youtube video on this problem so, as soon as my mail order battery arrives (with tool kit), I expect to be able to put it in easily. I am still amazed that the 680 has virtually hidden screws... you have to take off the antenna, then the case screws are accessible. Take them out and the case can be pried open.
Cheers,
Roger
из
Добавить комментарий
1 ответ
Выбранное решение
The antenna guide for this device shows some tiny screws on and behind the antenna that can be removed. After removing those screws, a spudger will get the case open.
If this solves your problem, please come back and mark this answer as accepted. Thanks!
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
Roger будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 280
