The second generation of the Mazda 3, also known as the Mazda3 and Mazda Axela, sedan and hatchback series by Mazda.
Вопросов 13 Показать все
D/S window is not working!
I have a (2010) Mazda 3 sedan & my Driver Side window suddenly doesn't work , but the other 3 window works fine. I'm curious if it could be the motor or switch? How do you remove the switch panel as well? Thanks everyone!
Это хороший вопрос?
Оценка 1
Добавить комментарий
Ответов (2)
Наиболее полезный ответ
Hi Johnny,
It could be the switch/regulator. I would start from there. Then I would check the motor of the window.
Here are the instructions on how to remove the panel. A guide with images (although for a 2004 model) you find here.
I am not sure if this would fit your model/make and if at all necessary, but check this out.
Steffen
Был ли этот ответ полезен?
Оценка 1
Hey, I attached the interior trim workshop manual from Mazda for this specific vehicle
2010_Mazda_3_Interior_Trim_WORKSHOP_MANU.pdf
Serge
Оценка 0
Добавьте свой ответ
Johnny будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 1
За последние 30 дней: 4
За всё время: 6,888
