Четвертое поколение iPhone. Ремонт прост, но дисплей должен быть заменен в сборе с сенсорным стеклом. Версия GSM; 8, 16 или 32 ГБ памяти; модель A1332; в Черном или Белом цвете.
2375вопросов Показать все
How do I fix iPhone 4 'Error 2001'?
Hello, my iPhone 4 went into recovery mode after the Apple logo kept going on and off but would not boot up fully. I get the plug into iTunes logo and when I go into iTunes to restore it, it gives me 'Error 2001'. I just called Apple and they said it is a hardware issue. It is not under warranty anymore. What part could be causing this?
Это хороший вопрос?
Оценка 6
Добавить комментарий
8 Ответов
Наиболее полезный ответ
Based on the information found here, it sounds like replacing the battery wil solve the problem for you, and you can find those batteries right here.
iPhone 4 Battery Изображение
Продукт
iPhone 4 Battery
$11.99
Был ли этот ответ полезен?
Оценка 5
2 Комментариев:
replacing the battery worked for me! i had the exact same issue. Thanks!!!!
из
worked for me also! Cheers!!
из
Replacing the battery not work for me, any suggestion??
Оценка 0
1 Комментарий:
Hi,
I am having the same problem! Did you ever find a solution?
Thanks
из
I have moved the whole logic board to a different chassi and I still get 2001 error
Оценка 0
This problem is probably related to the battery. I had the same problem, when I unplug the phone, it stops working. I also had this error 2001 when trying to restore my 4s.
Оценка 0
100% best solution!!
It is due to battery, but no need of replacement...
Yes, just ask in any mobile shop to put charge to your battery externally..
Now try inserting battery and restore will be successful!
Enjoyyy!!!
Оценка 0
Is there anyway to charge the batter at homes without going to a shop? (I have the same problem)
Оценка 0
1 Комментарий:
i'm sorry, with our cable it won't be charged. So please try to charge your battery in any other way. The only thing is to charge your battery... do not pay for any new battery.
из
You're the only person that has to do that
Оценка 0
1 Комментарий:
The best way for my family to come out and get my hair is done
из
How to Connet network of sprint
Оценка 0
Добавьте свой ответ
Josh K будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 16,279
