iPad Mini touch replacement went really really bad.
I changed an iPad mini touchscreen, not first time doing this.
Well the thing is that everything went to s#!t.
My standby wake button doesn't work.
My touchscreen stopped working. i even tested another touchscreen with the little connector board already soldered and didnt worked either. Then i tested both touchscreens and worked properly on a different iPad Mini.
The battery is at 78% and im getting the full charged icon.
It is restarting itself every 5 to 10 minutes.
I was able to perform a restore via itunes, but the issues persists.
I disconnect and reconnected the battery, the issue persists.
Any help, please!
Это хороший вопрос?
1 Комментарий
Did you install the flex cable correctly? You'd better ask professional to help you find out the problem.
из alinachau
