actually i read this post > http://forums.crackberry.com/blackberry-...
and it was very usefull...and the picture witch came with..
the problem was that the wifi antenna (black coaxial cable) is vary sensitive and i was broken it.
The antenna location is at the top right side of plabook, if you looking at from the back side(witch the logo of bb locate) and is actually above the speaker witch is not removable..(the left speaker is).
what you have to do:
1)open the back cover and remove the screws to release the right speaker
2)remove the tape witch prevent speaker to move in order not to cut the cable of the speaker
3)locate the antenna witch is on the speakers top right corner and check if it's broken
it looks like this
4)the cable is coaxial...so the outside cable is negative and is in touch with the small metal chassis (witch is difficult to be broken) and the inner is the positive and it's very very fragile....you can see in the pic!!THERE IS THE PROBLEM.. it maybe broken...
now....you have to connect again with the chassis with an iron solder (that i was do)it is difficult but you can do it without buying a new antenna witch is more difficult to replace it.
You must have in your mind that you have close the circuit and negative and positive of the antenna must be at the same chassis.
tools you need is (except the tools to open the back case witch is necessary) an iron solder with solder wire and an electronic poly-meter in order to check the right assembly
unfortunately I didn't record a video during the process
ps. very sorry for my bad English.
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
0
Отмена
Scroll through this thread to find the appropriate place for this comment. Then, click "Attach comment to this post" to move it.
