Yamaha YPG-225 76-Key piano keyboard, released in 2006
keys on the keyboard stop working
Hello some of the keys on my keyboard stop sounding. Does it means i´ve got a broken key? I am sure the keyboard hasn´t been hitted by no means.
Это хороший вопрос?
Счет 10
31 Комментариев
Hello, my yamaha keyboard stops playing after about 10 minutes. To start it again I need to hit the middle leg of the transistor with one of the wire. What could be the problem?
из
Replace the transistor or resolder it to the board
из
my keyboard has the same problem with some of the keys not sounding but i have a Roland D-20 Multi Timbral Linear synthesizer Multi Track Sequencer are the same thing happening to to my keys
из
My keybord has aproblem when i press one key it sounds two notes extra both one note up and the other one lower at the same time
из
Hi ser, my yamaha keyboard has aproblim, when I turn on thers com's up unexpected error what are whe doing them
из
Показать ещё 26 комментариев
Добавить комментарий
10 Ответов
Выбранное решение
Hi Mario,
You can use the guide for troubleshooting the YPG-225 provided by ifixit here. There is a section labeled "Keys don't produce sound". If you need the manual for this keyboard, it is here.
If those keys which do not produce a sound are somehow hanging (are lower than the other keys) and are somehow slack, the problem is related to broken keys. They need to be replaced. In this case, you can use this guide here on ifixit.
Just keep us posted what you figure out.
Steffen
Был ли этот ответ полезен?
Счет 8
3 Комментариев:
I love this website and the help provided by people like you. Thank you!
из
Hi. Thank you. Where can I buy replacement keys for my keyboard (Yamaha DGX 220, same as YPG 225 I think)? Will DGX 230 replacement keys work? My problem is that a Db key is a bit loose amd wiggly. It will often play louder than its supposed to.
из
This tutorial is of my exact keyboard. Is there a tutorial for when fixing all of one key across the entire keyboard? E’s in every octave have stopped working. Every other key works great.
из
The problem isn't usually the board.. its the rubber contact that either need replacing or cleaning. Clean with pure alcohol.. I use Isopropyl alcohol and a lint free pad like chamois. Don't use cotton bids.
If the fault is on the first octave the part number for the contact is V3413800
Top Octave? V3413700
All the other octaves: V4313600
If it is the board its in two halves... lower half. Pt number is V3414200 and the top half is V3414300
Contact Yamaha in your country and ask for spares dept, In UK the number is 01908366700 You can pay by card.
cheers
Iain (the engineer)
Keyboard Repair Centre, Birkenhead. UK
Счет 1
6 Комментариев:
How do you clean the rubber contact?
из
Clean with alcohol and lint free cloth see my post above.
из
My PSR970 speakers sounds like there water when I play it but there isn’t. What’s the problem?
из
"A" Key is not working in all octave in my Yamaha psr-410
из
Hi, I have a Yamaha psr-e223 and after removing the rubber contacts and cleaning/undusted the board, the B2 flat note keeps "ghostly" triggering itself, I turn it off and on but after a while it triggers itself again, first randomly beating but then soon gets stuck pressed on,
disassemble everything again and double checked, but the note keeps triggering itself with not external/mechanical touch to the board. where is the problem? Can't find any help on line about this.
из
Показать ещё 1 комментарий
My yamaha dgx 230 had the same problem too, except, if I pressed it lightly, it sounded as if I were pounding on it. And the bad thing is, it happened to 14 notes, which were the same G#'s and the same D's. But if I press on it normally, it doesn't make a sound. Do u think it has something to do with dust or the rubber pads?
Счет 1
8 Комментариев:
If it's all the same notes it's more likely to be the connections from the board to the main board. Or a crack in the track from the pad to the connector on the contact board
из
I have the same exact problem. All D keys and G# keys stopped working
из
I have the same problem.. when i press g or d keys both g & g# plays
из
I had a problem exactly like this on my yamaha psr 463.. I contact the service center but they're close due to lockdown... But i didn't want to open it myself as it still have warranty so i decided to blow below the keys with a hair dryer for 2 minutes and and guess what, it worked.... I'm reading all these post and decided to try that and I'm posting this as soon as that happened. Hope that helps
из
I just had the exact same problem, D and G#s weren't working. I followed the procedure with a hair dryer just as said in the previous comment, and it worked!!! :D :D Thank you @sawmajr
из
Показать ещё 3 комментариев
I'm a Yamaha engineer at Keyboard Repair Centre in Wirral.
I have had this fault in the past. It may be the volume control which has gone high in value. If you need the part number then let's know. Its not a difficult job but you need desoldering and soldering skills.
Счет 1
2 Комментариев:
Oke, that's great!. I would like to purchase that part then.
Can you indicate what to do next
Regards
Hugh
из
Hi, I have a Yamaha psr-e223 and after removing the rubber contacts and cleaning/undusted the card, the B2 flat note keeps "ghostly" triggering itself, I turn it off and on but after a while it triggers itself again, first randomly beating but then soon gets stuck pressed on,
из
Can you use spirit to clean the rubber contact or the circuit board....I also use Yamaha psr e423 and some keys seized to sound and I realized the problem is from either the rubber or the circuit board.. I need help please.
Счет 0
1 Комментарий:
Anything that does not leave a residue. All ohol is best... try vodka
из
I tried disassembling & cleaning, and more keys "died". I found that if I hit the keys over and over and over, it seems to come back to life.
This site seems to offer some replacement parts:
https://syntaur.com/yamaha_dgx.html
Счет 0
I have yamaha psr i455, from yesterday its D# and A key of every octive was not working. I am trying many ideas which givesn on internet. I have a hair dryer i use on my keyboard and now my keyboard is working properly. I think its lhappend because of moisture due to rain… i purchased Silica Gel packet and kept near to keyboard then after no such problem happened.
Счет 0
1 Комментарий:
If it is all the same note that fails, then there are 2 possible reasons for this. 1) there is a break in the copper track on the pcb or 2), a bad connection on the edge connector. If 1) then it is not an easy fix. If 2) then it could cured by resoldering it.
из
I just had this problem where my E and Bb keys had stopped working entirely.
I used a firm slap directly to the right of the logo above the keys to jostle things back into place.
Works so far, will update if anything changes.
-Roon
Счет 0
2 Комментариев:
Hi, on my Yamaha e223 Bb2 note triggers itself even without the rubber contact on it. The board is clean and yet it starts sounding by itself, only when reassembling rubber contacts and keys and pressing the E note on same octave the sound stops, as if pressing E interrupts the signal of Bb to the board, but as yet another issue, E doesn't play at all ever since...was that the same issue of yours?
из
Yamaha psr e 343 keybord d&g# key all octiv not working
из
Same thing here. I just got a brand new PSR 373 and after just 1 month the D and G# keys of all octaves stopped working. I sent it to the repair shop and I am waiting their evaluation to see what happened
Счет 0
1 Комментарий:
I have a yamaha clavinova clp 920 I'm trying to rescue. I ha e tried and tried but the right half of the keyboard won't make sound unless I press it very hard but the note will note sustain its just a quick little note. Iv tried Cleaning the keyboard contacts but it does nothing. I wanted this to work so badly. Does anyone know how I can get the right half of the keyboard to play notes again?
из
The Yamaha YPG-225 has 4 ribbon cables attached to the keyboard. The keyboard is in two separate sections: The lower 33 keys (E to C) with a 6-wire ribbon cable going to the main board, and the upper 43 keys (C# to D) with an 8-wire ribbon cable going to the main board. These two ribbon cables carry octave sensing for groups of 6 keys, at most, across the keyboard. So if a group of 6 contiguous keys are not working, it will mostly likely be a problem with one of the wires in these ribbon connectors not making the connection to the main board.
There are also two ribbon connectors with 12 wires. There is one short jumper ribbon connector between the two keyboard sections and one long one to the main board. These ribbon connectors carry key note information, all the keyboard "C" keys on one wire, all the C# keys on another wire, etc. So, if all the "C" keys are not sounding, it is probably a broken connection in one of the wires in the two 12-wire ribbon connectors.
I was able to fix a problem on the upper part of the keyboard. All the "E" keys and "A#" keys were intermittently not sounding. If the 12-wire jumper cable socket on the upper keyboard side was rocked, the problem either went away or got worse with more keys not sounding.
First I tried disconnecting the jumper ribbon cable at its two sockets, cleaning the wires, and then reconnecting. Do this by using your fingernails to push up the two ends of the socket to unlock it. Pull out the ribbon cable, clean it, then reinsert the ribbon cable wires all the way and then push down the two ends of the socket to lock it back in. The sockets are on the bottom of the keyboard circuit boards, so yes, you do have to remove all the keys, and all those circuit board screws.
This didn't work. I assume there must have been cracked connections around the ribbon cable socket, or the socket was no longer holding the cable wires tightly. The plastic on one edge of the keyboard case was cracked open so, at one point, the keyboard must have been dropped.
I finally ended up overriding the jumper ribbon cable with soldered connections between the two sockets using single strand wire-wrapping wire. Make sure you get the connections right. There is one 12-pin socket on the upper key circuit board. Another one on the lower key circuit board for the jumper - these pins are in reverse order. And finally there is a third 12-pin socket on the lower key circuit board for the main long ribbon cable to the main board - these pins are reversed again. All the 12 pins in these 3 sockets should be connected. I soldered the first and third socket connections together with 12 wires.
A couple extra thoughts: First, the keys come off in octave or less sections. The sections are locked into place with two plastic clips at the top of the keys. Push in one clip at a time and gently lift at the top corner of the key section to remove it. If you are gentle, the black and white keys can stay together as one unit. Second, I don't believe the black carbon cylinders inside the rubber gaskets need cleaning as much as the circuit board traces that they contact. The traces are easy to clean. Remove the rubber gaskets, spray some isopropyl alcohol or Cramolin on a cloth and then wipe along the traces.
Счет 0
1 Комментарий:
A third idea. The rubber gaskets on the keyboard circuit boards hold black carbon cylinders that will short out traces on the keyboard circuit board when pressed, which sounds the key. Each key has two carbon cylinders, one shorter than the other. When pressed lightly, only one cylinder contacts the circuit board key traces. When pressed harder, both cylinders contact the circuit board shorting out the key traces even more for a louder sounding note.
An understanding of this arrangement can perhaps answer some of the questions presented above. If one of the carbon cylinders is loose it will bounce against the trace when pressed resulting in the sound triggering multiple times. If the longer cylinder is missing, light key pressing won't sound at all.
из
Добавьте свой ответ
MARIO L буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 11
За последние 7 дней: 36
За последние 30 дней: 193
За всё время: 73,168
