Repair information for the 7" Android tablet by Samsung. Fixing this device is straightforward, and requires only common tools. The Samsung Galaxy Tab is an Android-based tablet computer produced by Samsung. The 7-inch Samsung Galaxy Tab is the first model in the series. It was introduced on September 2, 2010
110вопросов Показать все
What should I do,if I cannot power on my samsung tablet device
how to fix my samsung tablet device since i cannot power on .I was watching in you tube and then it suddenly hangs up and i tried to power off my device and yet it does, but sad to say that until now i cannot open my device nothing will appear in the screen. I have no idea how to fix it. I really need your help.Thank you
Это хороший вопрос?
Оценка 5
2 Комментариев
Trying to turn on my tablet just coming on to Samsung Galaxy Tab3 wont do anything else .
из
Hello sir mera Samsung galaxy t561 on ho rha hai but.. Sirf Samsung likh rha hai.
Kaise sahi hoga....
Please mail kijiye email prcrnjn@gmail.com
из
Добавить комментарий
14 Ответов
Выбранное решение
If you have tried charging it, replace the battery.
Samsung Galaxy Tab 7.0 Battery Replacement
Был ли этот ответ полезен?
Оценка 3
1 Комментарий:
i hear my taB GOING ON AND OFF WHEN I HIT POWER BUTTONAND VOLUME I DROPPED IT AND IT cracked on inside not outside when turn on i seen whiteb csreen and cracks on the left inside part of tablet
из
Наиболее полезный ответ
Press volume key and power key a The same time for about 10 second hope you fix it mine just needed a update didnt tell me and justed Turned off its probably just a unexpected update
Оценка 13
9 Комментариев:
Thank you, this worked for my Samsung Galaxy Tab A.
из
Thank u so much it fixed mine
из
Wow it worked your an angel. Thank you so much
из
Thank you so much. This worked awesome!
из
Thank you so much that helps and it worked you're an angel,
из
Показать 4 больше комментариев
Thank you izabelle this fixed my tablet..... I am shocked that I took it to samsung store and they didn't know how to fix it....
Оценка 2
I had same problem looked up an android forum on internet there was a you tube clip showing you how to disconnect the battery. Quite easy to do once you got access to it.
Left disconnected for 30 seconds, then put it back together plug power lead in turn on and hey presto few grey black screens and then battery icon and charging up.
Оценка 2
1 Комментарий:
how did you open your tablet?
из
i cant power on my tab, scren is blake
Оценка 2
this happened to me before and i tried to turn it on a couple times and it didnt work i left it charging over night for 2 days and in the morning it was on
Оценка 2
i have problem in tab 3 ... i m not able to completely to charging 100% . full day if i keep for charging also it will 40 % only ... some time it will automatically it will get switch off & restart ... please help me
Оценка 2
My Samsung 10" tab 3 won't turn on IV tried all the buttons and held them down and it's been on charge all day I can't take the tablet apart because I can't tell my parents or I'll get told of what do I do please help meee
Оценка 2
We have an 8" Tab 3 and if you don't use it for a few days it just turns off. Tried charging it and eventually the charging will start - has been upto 2 weeks with a slow trickle charge!! The tab was a Christmas present and the battery should not need changing!
Оценка 1
great it helps me a lot. thank u very much
Оценка 1
i downlode anroid 4.1.2 veson then i instrol after my tab newar power on
Оценка 1
try to find a solution here http://mans.io/brand/Samsung
Оценка 1
I have a problem with my tablet I haven't been using it over a year now when I put in on a charger its blank no power no nothing please help
Оценка 1
u guys i have the same problem on my tablet samsung 7i press and hold on the power and volume button it finally works thank u guys so much and have a nice day
Оценка 1
Добавьте свой ответ
aileen будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 4
За всё время: 23,917
