Updated version of the original iPad 2, released in March of 2012 with a smaller die processor and updated internal construction. Repair will require the use of heat and careful prying.
73вопросов Показать все
Ipad 2 Damaged Digitizer connectors
Hi,
I damaged the digitizer connectors during an attempted repair. Not only did one of the clips break off (I have seen suggestions on this), but I actually pulled the black tape off the top of the connector (I thought the cable popped off like it does on the Itouch), then the pins themselves starting coming off. I know the connectors can be replaced by soldering but I am hoping there is a work around because the soldering process looks pretty tough.
Any help would be appreciated!
Это хороший вопрос?
Оценка -1
Добавить комментарий
6 Ответов
Выбранное решение
Lisa Graf, if the pins pulled out of the connector, then the only appropriate repair would be to solder it. Place an image of your broken connector and the logic board damage so we can see what you see. There might be other possibilities. the connectors are available at places like this. Hope this helps, good luck.
Был ли этот ответ полезен?
Оценка 1
Hi,
I have something similar to tho s,:( is there any life left of this iPad?
any help would be highly appreciated :)
Оценка 0
1 Комментарий:
What would be the best way to repair it?
solder?
из
It's hard to see from the picture, but it looks like the fpc on the right was not removed? If that's true and all the pads are intact it's not dead yet.
Оценка 0
Yes, I would remove the damaged f p c then solder on the new on being very careful of the pads.
Оценка 0
In the photo above, the fpc is removed. Thats the damage on the logic board. :/
Оценка 0
Well Nikki, looking at the logic board there, it looks as if the board is beyond repair. It looks like the soldering gun or whatever you used did quit a bit of damage. Once the traces are messed up, then there's no hope of repair from what I've seen. I hope that I can been proved wrong on this by someone with some bada** soldering skills. I'm actually in the same boat with the digitizer connector tab being broken off and having to desolder and solder a new connector on. I'm really apprehensive about doing this though as I really don't have a whole lot of experience with soldering such SMALL parts and with the traces so close together.
Оценка 0
Добавьте свой ответ
Lisa Graf будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 2,523
