Processor: Intel® Core™ 2 Duo Processor T5750 2.0 GHz
No WIFI options in panel or in configuration
I have problems with the Wi-FI configuration beucause it´s not apper the option to detect a Wireless Network. It´s only apper the cable Network (Ethernet) and the DIAL UP metod.
Please help me.
Это хороший вопрос?
Счет 0
Добавить комментарий
2 Ответов
Выбранное решение
Visit the computer manufacturer's website and download the driver for your adapter and install it. If that doesn't work, then it's possible that the wireless adapter has died. Of course you also want to make sure that it is turned on. "Your notebook has an IEEE 802.11 radio for accessing the Internet through a wireless access point or communicating with other computers on a wireless Ethernet network. To turn the wireless IEEE 802.11 radio on:
1. Enable the wireless IEEE 802.11 radio by sliding the wireless network switch backward to the ON position.
If the wireless IEEE 802.11 radio does not turn on automatically, press FN+F2. The wireless status indicator turns on.
OR-
Click (Start),All Programs,Accessories,then click Windows Mobility Center. When the Windows Mobility Center window opens, click Turn wireless on." from the operators manual. Hope this helps, good luck.
Был ли этот ответ полезен?
Счет 1
The best way is downloading the latest driver from your machine`s manufacturer`s website and install it. If installing the updated driver does not solves your problem then it can be a hardware level problem in this case you might have to go to hardware shop. Good Luck
Счет 0
1 Комментарий:
already been suggested ...read the answers. You are answering a lot of old, already accepted and already answered questions....
из
Добавьте свой ответ
julianmlugo буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 3
За всё время: 2,470
