will not start,and door does not lock.
will not start. the door does not lock.
help!
Это хороший вопрос?
help!
Это хороший вопрос?
Door or Lid Latch Assembly
If the washer lid or door won't lock the lock and switch assembly might be defective. This is a very common problem. The lock and switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly
Main Control Board
If the washer door won't unlock the problem might be the main control board. This is not common. Normally the problem is with the lock mechanism.
Был ли этот ответ полезен?
За последние 24часов: 2
За последние 7 дней: 6
За последние 30 дней: 12
За всё время: 3,371
